Author Topic: WXSIM 2019, Build 1.0 Released!  (Read 2385 times)
Offline Tom Ehrensperger
  • Win NT 10.0
  • Firefox 64.0
« on: January 13, 2019, 02:54:04 AM »
I've just released a new version!  Also, I've cleaned up/updated the manual and the web site a bit.  To UPGRADE (for existing users), use this installer:
www.wxsim.com/wxsimupg.exe
If you are NOT a registered user, you can get the demo here:
www.wxsim.com/wxsimdem.upg
I'm pasting in below the changes implemented in the last few versions.  Also, note that WXSIMATE (included) is now Version 7.0, which has updated URL's (which all work!)
Thanks, as always, for your support of my programs!
Tom
Version 2019 Build 1.0, (completed January 11, 2019) has the following change relative to Version 2018, Build 1.3 (described below):
(1) A new output file, latestblyr.csv, has been added, to display a variety of data related to nocturnal and capping inversions.  See ‘Boundary Layer Predictions’ in section 19, above.
(2) Minor formatting changes were made on WXSIM’s Data Entry form, to allow display of tenths of a degree in the normal max and min temperatures for the date, and also to allow proper display of slightly longer site names.
(3) Minor formatting changes were made in wret.exe, to allow display of slightly longer file identifiers.
Version 2018 Build 1.3, (September 19, 2018) had the following change relative to Version 2018, Build 1.2 (described below):
(1) In the latestshort.csv file, the time will now be consistent with the Daylight Saving Time setting.  Perviously, during DST, the date would change according to DST, but the time wouldn’t.  This is still the case in latest.csv, as I did not want to “break” any scripts that might be in use, which are already adapted to this.  The latestshort.csv file is actually a custom file created at the request of a single user, who also requested this change.  The file is of course available to anyone who has a need for it.
Version 2018 Build 1.2, (completed August 25, 2018) had the following changes relative to Version 2018, Build 1.1 (described below):
(1) A problem (apparently introduced in a recent version), which casued production of unwanted .csv files (i.e. when .wxf only is checked) was corrected.
(2) Maximum daily solar radiation was added to the latestdaily.csv file, right before max UV, at the request of a user.  Note that this is a smoothed value, so that on partly cloudy days it will “underestimate” the brief maxima which occur as the sun comes out from behind clouds.
Version 2018 Build 1.1, (completed August 5, 2018) had the following changes relative to Version 2018, Build 1.0 (described below):
(1) An item that was new in Build 1.0 (below), but which I forgot to list, is the “Adjust” button next to Auto Haze under Refinements on the Data Entry form.  When you click this, a form appears which allows you to specify an offset for the amount of haze generated by the Auto Haze routine.  The primary motivation for this is the addition of solar panel power output forecasting (described below), as this can be quite sensitive to the amount of haze.
(2) Changes were made in the solar panel algorithms to allow a new parameter related to the response of the panels to diffuse (scattered) versus direct sunlight.  Originally, this was included as a constant, but experience with a second customer, with a different brand or type of panel showed that this can vary.  Unless the new value is specified, the program defaults to the original constant.
(3) Another parameter was added to the solar panel algorithm: maximum inverter power.  My second customer has an inverter which occasionally maxes out at a certain wattage, so I added this as an optional variable.  If not specified, the inverter maximum power is assumed to be unlimited.
(4) A bug in Build 1.0 had caused the new wet bulb global temperature to be left blank in the first line of latest.csv.  This has been corrected.
(5) In wret.exe, a message in Build 1.0 had pointed out the lack of Fire Weather Index in older forecast files.  However, this turned out to stop execution during analysis runs (including with autoleearn.exe), so it has been removed.  The default fire index for older forecast files is now set to zero, as it cannot be properly calculated from the data they contain.
(6) In wret.exe, the number of checked items in each section (‘Temperatures and Thickness’ and ‘Other Data’) has been increased from 15 to 20.  The blue-text help items for these also now reflect these changes.
(7) The print option in WXSIM (‘None’, ‘Short Form’, ‘Long Form’, or ‘Graph and Summaries’) is now saved on exit.
(8) The latestsolardaily.csv file now outputs kilowatt-hours in the last column, instead of watt-hours.  (The column heading had previously said kw-hr, so this change effectively corrects a mislabeled column heading, which itself remains as before).  Also, minimum and maximum daily panel temperatures for days with insufficient data are now reported as “M” (“missing”) instead of the previous obviously erroneous defaults.
Offline atsio
  • Weather at Thessaloniki - Northern Greece.
  • Macedonia is GREECE! Study history!
  • Thessaloniki - Greece
  • Win NT 10.0
  • Chrome 71.0.3578.98
    • Weather conditions at Thessaloniki Historical Center-Central Macedonia-Greece
Re: WXSIM 2019, Build 1.0 Released!
« Reply #1 on: January 13, 2019, 01:30:17 PM »
Tom, first WXSIM 2019 forecast ran without any issues!!!  8)
Thanos
Offline Stegrie
  • Germany
  • Win NT 10.0
  • Firefox 64.0
    • Wetterstation Johanngeorgenstadt
« Reply #2 on: January 18, 2019, 10:18:58 AM »
The first run after upgrade was perfect, i will wait how wxsimlite goes. :D
Stefan
Weather Station - Johanngeorgenstadt
Davis Vantage Pro 2 Plus - WXSIM,Blitzortung ,WD, 2 Soil Temp/Moist + Solar/Rad.
System: Windows 7
Offline DrRob
  • Win NT 10.0
« Reply #3 on: January 19, 2019, 11:58:47 PM »
Hi Tom.
I am receiving "Error 6 in wxmain" on this build.
The location of the error is variable (between day 2 and day 4)
It changes based on the time of day the program is run.
I notice during my day that between 10 am and 4 pm there is always an error.
As I was up early this morning, I noted that the error has been occurring since 4 am.
(all times in gmt+10)
Rob
Offline dsscheibe
  • Phoenix, AZ
  • Win NT 10.0
  • Firefox 64.0
    • Scotts Weather Station, Cactus Wren, Phoenix, Arizona
« Reply #4 on: January 20, 2019, 08:03:23 AM »
page comes up missing 404
Scott
Davis Pro2 Plus daytime aspirated, wired
Weather Display
Offline oreitsma
  • Assen, Netherlands
  • Win NT 10.0
    • Weerstation Assen
« Reply #5 on: January 20, 2019, 08:05:11 AM »
Hi Tom.
Rob
I`m glad that I am not the only one.
I have exactly same problem.
The run after the run with the error goes fine again.
I had it two times now with this new version.
Hope Tom can find something.
Brgds,
Oebel
Offline broadstairs
  • Stuart
  • Broadstairs, Kent, UK
  • (Linux Mint)
  • Firefox 61.0
    • Broadstairs
« Reply #6 on: January 26, 2019, 09:50:57 AM »
Past couple of days I've been seeing errors on this release, error 70 several times followed by several error 6. A reload and download of wxsimate data and rerun of lite and subsequent run goes ok. If this happens again I will go back a release which did not expose me to this.
  • Win NT 10.0
  • Firefox 64.0
« Reply #7 on: January 27, 2019, 07:30:05 PM »
Sorry about these errors!  Which happens first, error 70 or error 6?  (I would think 70 might happen AFTER 6, but I'm not sure).  I don't know if it's something about the new version, or if there's been a data problem lately.  If you see it again, please send me custinit.txt, rgcode.txt, localdat.txt, localcal.txt, wxsmini.txt, wdata.txt, cty.fdt, fdata.txt, and cor.txt, as those are probably all the files that could be involved.  Also, if you revert to another version and can definitely show that the new version has the problem and the old version does't, that would be helpful.
Thanks!
Tom
Offline broadstairs
  • Stuart
  • (Linux Mint)
  • Firefox 61.0
    • Broadstairs
« Reply #8 on: January 28, 2019, 07:40:38 AM »
Thanks!
Tom
Tom the problem is intermittent and as I was not watching it I don't know for sure which error came first, as a guess it was the 70. Has not happened for acouple of days now but am wondering if it could be related to when lite runs the analysis which is not every night. I'll watch it over the next few days and will send the files if it does happen again.
Offline broadstairs
  • Stuart
  • (Linux Mint)
  • Firefox 56.2.6
    • Broadstairs
« Reply #9 on: January 29, 2019, 09:04:29 AM »
Well this morning WXSim managed to crash my PC - it hung up with an error 480 from WXSim and I needed to power off my PC to recover as nothing worked. I have reverted to the previous version for now.. I have gathered the files mentioned previously but with this error I dont know if they are valid.
Offline Mearns
  • Glenbervie, N.E. Scotland
  • Win NT 10.0
  • Firefox 60.9
    • Glenbervie Weather
« Reply #10 on: January 29, 2019, 11:38:06 PM »
Have been running this build for 10 days - no problems so far.
Tony
Wireless Davis VP2 USB
WD 10.37S Build 95 on Windows 10 64bit
www.glenbervie-weather.org
Offline jahuff
  • Northern New Hampshire, USA
  • Mac OS X 10.14.2
  • Safari 12.0.2
    • Weather Data Pittsburg, NH
« Reply #11 on: January 30, 2019, 12:52:02 PM »
Hi Everyone,
Build 1.0 running well here.
Thanks Tom.
John
Offline hrvistaweather
  • Tasmania
  • Win NT 10.0
« Reply #12 on: February 02, 2019, 08:14:03 AM »
Hi Tom,
As you know I'm in a rather rough situation at present with past weeks of living in thick smoke and fires threatening us (all occurring at the wrong time as we are a third way through preparing our property for sale due to my health declining, which will render the weather site offline eventually = as we have no idea where we will be after we sell). So at last yesterday I had a breather from the smoke as it cleared slightly here and from the exhaustion of 24hr monitoring (though still on Watch and Act). I found this thread and decided to update wxsim even though I will shut down in due course and although had a few teething issues, got it running OK.
However with ref to your comments quoted below, I found that my personal mysql script failed due to the inclusion of a new field in latest.csv this new field is the UTC date/timeUTC stamp though does not have a header.
I have rectified my own personal scripts (not used by others) so all good.
If you add a Header it will not impact mine. Though surprised I could not find any mention of this on the forum aside from my original post and Wim's reply at https://www.weather-watch.com/smf/index.php/topic,67079.msg539599.html#msg539599 which was all prior to this upgrade.
I also found a few other things in other .csv files which I'd like to question one day (when all this fire/move/etc is over, though no capacity left to go into detail on those.
Quote
(1) In the latestshort.csv file, the time will now be consistent with the Daylight Saving Time setting.  Previously, during DST, the date would change according to DST, but the time wouldn’t.  This is still the case in latest.csv, as I did not want to “break” any scripts that might be in use, which are already adapted to this.  The latestshort.csv file is actually a custom file created at the request of a single user, who also requested this change.  The file is of course available to anyone who has a need for it.
Kind Regards,
Stay safe and healthy where ever you are,
« Last Edit: February 02, 2019, 08:25:24 AM by hrvistaweather »
Tony
Offline kocher
  • San Sebastian (Spain)
  • Win 7/Srvr 2008R2
    • San Sebastian - Arriola
« Reply #13 on: February 02, 2019, 10:02:42 AM »
Regards Tony
These information have left me worried.
Above all, I wish you better in your health.
I also hope that your problems end with the risk of fire, smoke, sale of the house ...
I'm sorry that you have to close the page and, I'm sure you'll be back soon.
I am an enthusiast of your scripts for WxSim.
Effectively, with the WxSim update of October 2018, your scripts stopped working on my page.
In January 2019, I managed to solve the problem as indicated in:
https://www.weather-watch.com/smf/index.php/topic,66593.msg542442.html#msg542442
I pray for the solution of all your current problems.
Greetings from San Sebastian, Spain
Javier
« Last Edit: February 02, 2019, 10:05:42 AM by kocher »
  • Tasmania
  • Win NT 10.0
« Reply #14 on: February 02, 2019, 10:37:14 AM »
Hi Javier,
As always I thank you for your kind words.
Though at this stage I feel I may not have the capacity to continue after our eventual move, only time will tell.
Sadly I thought all was good after recent post, however I am now getting error 6, all was brilliant before the upgrade and also at a time of need while during ongoing fire situation I feel now I should have left well enough alone.
I am in a position where I am not able to monitor wxsim/website as I used to due to current situation so when I check it now and then I now find errors. such a pity, if it continues I'll just shut it down as that is not my standard displaying incorrect old not updated data.
Will see what happens, kind regards,
Tony
