Author Topic: Missing display data / faulty record  (Read 745 times)
Offline Ex-Whr
  • Perth WA
  • Win NT 10.0
  • Chrome 58.0.3029.110
« on: May 07, 2018, 03:02:31 AM »
Brian
Offline Ex-Whr
  • Perth WA
  • Win NT 10.0
Re: Missing display data / faulty record
« Reply #1 on: May 07, 2018, 03:31:13 AM »
Brian
   OOps .. looks like last did not got through
  Attached are two screen shots of my WD display and log data for today
 The display shows zero (0) rainfall for yesterday in rainfall section @ bottom left of screen, and shows 1.00 mm on graph. ( rain fall is correct measured against official BOM rain gauge)
  The log file also indicates rainfall as 1.0 mm.       However the log file and display also show that the rainfall total has been zeroed at 08:51 instead of 09:00.
  The log file also shows the wind dir at the same time has gone from zero to 32407. ..  But there is currently no anemometer attached to system  ( waiting on a transmitter unit)
  My system is Davis VP Pro2 and on a win 10 pc with 8 Gb ram and 256 Gb ssd drive .. WD ver 10.37570
 hope this gets into the system
Offline Ex-Whr
  • Perth WA
  • Win NT 10.0
« Reply #2 on: May 07, 2018, 03:35:42 AM »
missing jpg's
  • Davis VP2
  • New Zealand
  • Win NT 10.0
  • Chrome 66.0.3359.139
    • Weather Display
« Reply #3 on: May 07, 2018, 08:48:46 AM »
was WD running the whole time during the reset time?
Offline Ex-Whr
  • Perth WA
  • Win NT 10.0
« Reply #4 on: May 07, 2018, 09:02:45 AM »
Brian
  Yes ... As I was checking rain gauge (manual  BOM gauge ) as a check having been away in NZ for a month.
John Y
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #5 on: May 07, 2018, 11:10:59 PM »
keep an eye on it and see if it happens again?
Offline Ex-Whr
  • Perth WA
  • Win NT 10.0
« Reply #6 on: May 08, 2018, 01:33:04 AM »
Will do ..
Offline Ex-Whr
  • Perth WA
  • Win NT 10.0
  • Chrome 64.0.3282.140
« Reply #7 on: May 18, 2018, 02:51:15 AM »
Brian
 attached two graphs with suspect info       will send log file as seperate message..
 the graphs show in graph 1, it does not show correct data from approx 1500 yesterday as graph time line has not caught up to todays time and data.   data shows as a spike.
 on graph 2 in extreme conditions section Max temp displays 25.7 @ 3:13 pm( Which is yesterday ..??)  and min temp is 14.1 @ 9:01 (today ..? ) though the log file for today [ 18/05/2018 ] shows min temp of 14.0 @09:00..
There is no indication in Graph 2 that the max and min are todays or yesterdays ..(  ?? )  Can this be modified to display / indicate todays and yesterdays values ..???
Offline Ex-Whr
  • Perth WA
  • Win NT 10.0
« Reply #8 on: May 18, 2018, 03:02:05 AM »
Part 2 of Query
 Attached is log file for 18/05/2018
At 09:51the data is missing for 6 mins and the temp jumps from 17.4 @ 09:51 to 25.7 @ 09:57.    the Temp then reverts back to 17.8 @ 09:58... Also note the wind dir goes from 0 to 32407 @ 09:57.
The VP2 Pro console display showed the correct temp during this time with regular temp rises during this period.
There has been no change to set up since last glitch report .and anemometer should be installed in next few days as transmitter has arrived
Cheers
Offline Ex-Whr
  • Perth WA
  • Win NT 10.0
« Reply #9 on: May 18, 2018, 05:18:47 AM »
Brian
  Updated graph of temps display -  09 - 15 - 11 time .???
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #10 on: May 18, 2018, 06:20:00 PM »
I have not seen this problem before or seen other reports of this problem
is the time and date on the weather station console correct?
is maybe your pc restarting at around 10am, but restarting with the incorrect time?
maybe check your cmos battery?
Offline Ex-Whr
  • Perth WA
  • Win NT 10.0
« Reply #11 on: May 19, 2018, 02:18:51 AM »
Brian
  No All time correct and computer running, I was at computer at the time ..
Offline Ex-Whr
  • Perth WA
  • Win NT 10.0
« Reply #12 on: May 19, 2018, 02:22:25 AM »
Brian
   When anemometer is installed will reset all sensors and save copy of current data and start new data/log files..
  Any comment on display of max / min temps for previous / current day ??
cheers
