For those who don't want the Windows 10 power saving settings to put their PC or Laptop to sleep, close down the USB ports or generally mess with the working of their weather PC then this FAQ covers the settings to look at.
I have listed the settings I have on my own Windows 10 PC, which is set to remain on 24/7 with no password required on start up, to avoid issues if I'm not around and there's a power cut.
From your main Start Menu:
Settings > System > Power & Sleep > Additional power settings > to the right of "
Balanced (recommended)" click the "
Change plan settings" link > now click the "
Change advanced power settings" link and go through the following:
Balanced > Require password on wakeup >
noHard disk > turn off disk after >
neverWireless adaptor settings > power save mode >
max performanceSleep >
- Sleep after > never
- Allow hybrid sleep > off
- Hibernate after > never
- Allow wake timers > disable
USB Settings > USB selective suspend setting >
disabledPCI Express (if you have anything in the PCI slot) > Link state power management >
OffProcessor Power management >
- Minimum processor state > 5%
- System cooling policy > Active
- Max processor state > 100%
Display >
- Turn off display after > Never (optional but I leave it on as I also use a KVM Switch and it caused problems some time ago with the screen not waking up again
) - Enable adaptive brightness > off (doesn't effect power settings)
Notes:
I left out internet explorer & desktop settings as they have nothing to do with the settings I'm interested in for this FAQ.
If you don't see all of the headings above in your list then click on the "
Change settings that are currently unavailable" link above the list window.
Hope that helps.
