Author Topic: wxmate can't start working  (Read 4100 times)
Offline meteovas79
  • Larissa -Thessalia- Greece
    • Weather in Larissa - Greece
« on: November 05, 2007, 09:58:15 AM »
Hi friends,
I just get costumize files from Tom and tried start work it.I think i must open wxmate 1st and import local data and metar,gfs data etc.When i push import data button i wait about 5 min with no progress and then i get this message :
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.Net.WebException: The operation has timed-out.
   at System.Net.ConnectStream.Read(Byte[] buffer, Int32 offset, Int32 size)
   at System.Net.WebClient.DownloadFile(String address, String fileName)
   at wxsimate.Form1.getem()
   at wxsimate.Form1.downloader()
   at wxsimate.Form1.downld_Click(Object sender, EventArgs e)
   at System.Windows.Forms.Control.OnClick(EventArgs e)
   at System.Windows.Forms.Button.OnClick(EventArgs e)
   at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
   at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ButtonBase.WndProc(Message& m)
   at System.Windows.Forms.Button.WndProc(Message& m)
   at System.Windows.Forms.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 1.0.5000.0
    Win32 Version: 1.1.4322.573
    CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
wxsimate
    Assembly Version: 1.0.2707.27084
    Win32 Version: 1.0.2707.27084
    CodeBase: file:///C:/wxsim/wxsimate.exe
    CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
System
    CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
System.Drawing
    CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
Microsoft.VisualBasic
    Assembly Version: 7.0.5000.0
    Win32 Version: 7.10.3052.4
    CodeBase: file:///c:/windows/assembly/gac/microsoft.visualbasic/7.0.5000.0__b03f5f7f11d50a3a/microsoft.visualbasic.dll
System.Xml
    CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
************** JIT Debugging **************
To enable just in time (JIT) debugging, the config file for this
application or machine (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the machine
rather than being handled by this dialog.
have anyone any idea what's my problem?
Vassilis
