Weather-Watch.com
Weather and the Internet => Creating Weather Web Sites => Topic started by: jzinckgra on January 23, 2019, 01:17:24 PM
Title: How hard is to setup and use weather34 template?
Post by: jzinckgra on January 23, 2019, 01:17:24 PM
I have my own website and have been uploading to it from WD for years (www.weather911.net), but am interested in using the weather34 template, but have no experience beyond basic web design. I use host gator as the server. Would this be over my head to try and get this setup using WD? Thanks.
Title: Re: How hard is to setup and use weather34 template?
Post by: R_o_B on January 23, 2019, 03:05:04 PM
Have a look at the documentation found on the 'HomeWeatherStation Template - WD Version (http://wd34.weather-template.com/)' and if you need additional information or have questions, check the 'weather34 for WeatherDisplay (clientraw and WDapi) (https://www.weather-watch.com/smf/index.php/topic,67468.0.html)' thread in the Weather-Watch forums.  :wink:
Post by: jzinckgra on January 23, 2019, 09:09:15 PM
Thanks. I uploaded and extracted files to my root dir, but I'm getting a 500 internal server error when I try the test link. www.mysite.net/pwsWD/
Post by: niko on January 23, 2019, 09:35:52 PM
Is "mysite.net" really your domain name?
Post by: jzinckgra on January 23, 2019, 10:26:28 PM
No. www.weather911.net
Post by: wvdkuil on January 24, 2019, 07:59:24 AM
===> Maybe
there is a special setting at your provider, as using the test-program, the first script runs OK
http://www.weather911.net/pwsWD/_test.php
When using "inspect"  you will see that all but one php script is allowed to run. All others get a 500 error
Again when testing such an individual script it runs OK
http://www.weather911.net/pwsWD/_test.php?test=clock_small.php
All single scripts work as they should
http://www.weather911.net/pwsWD/w34_easyweathersetup.php
It seems that only scripts which do not include other PHP scripts work
EXAMPLE http://www.weather911.net/pwsWD/easyweathersetup.php  has the name of the previous script and the only thing is does is load the new version, but it fails also.
Code: [Select]
<?php
include 'w34_easyweathersetup.php';
Running the included script directly works fine http://www.weather911.net/pwsWD/w34_easyweathersetup.php
===> Maybe
you uploaded the scripts and they got the wrong permissions.
All scripts should have execute permissions to thew Apache user itself.
===> QUESTIONS
But whatever the cause, I can not solve it as it seems not to be an error or setting in the scripts
Do you know:
what version of PHP you are using? I attach a smal script, it displays all info about your PHP version
if your website is run with Apache or IIS
and  the provider where your website is hosted?
Post by: jzinckgra on January 24, 2019, 05:44:49 PM
===> Maybe
Code: [Select]
<?php
===> Maybe
===> QUESTIONS
Do you know:
What ver PHP should I be using? My site is hosted by hostgator. thanks.
Post by: wvdkuil on January 24, 2019, 06:31:50 PM
At least 5.6, better 7.1 or higher.
Post by: wvdkuil on January 25, 2019, 10:12:11 AM
I tested a few times and it could be a permission problem as I can generate the same 500 error when setting scripts as not-executable.
Every script which when run in the browser fails with a 500 error , runs correctly when loaded using a test-program.
EXAMPLE: http://www.weather911.net/pwsWD/easyweathersetup.php   fails with a 500 error
The script ttp://www.weather911.net/pwsWD/_test.php   works and loads
And when that working script loads the same example script : http://www.weather911.net/pwsWD/_test.php?test=easyweathersetup.php  it also works OK.
If you do not have time to check the permissions and set them correctly, you could  email me (not  a message on the forum) your ftpserver/userid/password and I can check.
Because I am as curious as you probably are, why it is not working 100%, why some scripts fail and others not.
Post by: jzinckgra on January 25, 2019, 05:55:36 PM
I checked the permissions. Read and Execute for User, Group and World are enabled. Write is only enabled for User. I went ahead and enabled Group and World for Write and it still doesn't work. When I open the pwsWD folder and see all the scripts, they have different permissions (see pic). Some of your links above that did work for you are not working now. Ver 5.6 is running
Post by: wvdkuil on January 25, 2019, 06:09:59 PM
Well, at least something is 100%.
Now all the scripts end in a 500 error. Even the scripts which worked previously.
So definitely there is some permission problem, I hope you will find it. Maybe contacting your provider will help?
Post by: jzinckgra on January 25, 2019, 06:15:06 PM
Wim,
See my post above yours with pic. Should Execute be enabled for all scripts? The pwsWD main folder has all permissions, but inside the folder, individual scripts are all different for permissions.
Post by: wvdkuil on January 25, 2019, 06:44:07 PM
Wim,
Normally all scripts have 644 with "apache".
The folders (and the contents)  to which the scrips write data have 755: ./jsondata  ./ chartsmysql/  ./chartswudata/
But your server is using "nginx" and maybe  that is different. I have no idea.
Maybe simple trial and error.
Remove the write group and write world form the pwsWD/ folder, it  should be 755 at most.
Check the  ./jsondata  ./ chartsmysql/  ./chartswudata/ folders also.
Set index.php and _test.php back to 644
Then test them if they work.
Post by: jzinckgra on January 25, 2019, 08:16:30 PM
The above fixed the issue. It seems to work now, but it says my php ver is "Info: Your current PHP version is : 5.4.45" under the easysetup screen. I know you said it should be 5.6 or higher, but is this a problem. It's odd because hostgator says the ver is 5.6.30. thanks.
Post by: wvdkuil on January 25, 2019, 08:54:02 PM
When you unzip the info.php from a few messages back, you can run it on you site and it will display the real PHP information.
Post by: wvdkuil on January 28, 2019, 12:43:48 PM
When I access your site, it is still not working correctly.   => http://www.weather911.net/pwsWD/
The index.php is only partly loaded and 12 scripts fail because of a 500 error.
The database-user & -password fields are simple html fields without any extra checking by easyweather.
If you fill in any normal characters, like 12345444444   ,
and press save at the bottom,
The field should contain those characters if you start easyweather again.
I therefor assume that the file is not saved when you click the save button. Maybe also because a 500 error.
Post by: jzinckgra on January 28, 2019, 12:44:27 PM
Win,
A few more questions. I'm not sure I'm using the correct host name, but the credentials are the same ones I have in WD. Why does the cpanel password stay blank? I enter in password , then save, but when I go back, it's blank again.
Do I have the correct webcam link? Thanks.
(https://uploads.tapatalk-cdn.com/20190128/a30bc1400550d9c64a78ec9de6590e12.jpg)(https://uploads.tapatalk-cdn.com/20190128/85db9018db841c8470347e59a3444425.jpg)
Post by: wvdkuil on January 28, 2019, 12:59:04 PM
Win,
Already answered in previous message https://www.weather-watch.com/smf/index.php/topic,67583.msg542906.html#msg542906
When a script fails after you hit the button, it can not write the information.
So first try with a fake password with normal characters. Maybe that is saved.
The webcam will not show as the scripts run in a 500 error.  But the correct link would be ../capture2.png
Post by: jzinckgra on January 28, 2019, 09:40:25 PM
Is this how the link in the php file should appear?
#-------- www.weather911.net/capture2.png
Post by: niko on January 28, 2019, 09:54:42 PM
www.weather911.net/capture2.png does not exist, but there is an image at
http://www.weather911.net/capture2.jpg
Post by: jzinckgra on January 28, 2019, 10:01:11 PM
Right, but I'm still getting a server 500 error. The http link is direct to my website. I was trying to make sure the php file and the link I entered was properly entered, including the dashes. Still may be a permissions issue which I'm working on. Thanks
Post by: bitsostring on January 28, 2019, 10:36:42 PM
Enter the link as
../capture2.jpg
Post by: jzinckgra on January 29, 2019, 01:20:11 AM
Looks like it's a permissions issue. I see duplicate php files in the main pwsWD folder and then again in the pwswdupdate folder. Do I update all php files in both folders for the duplicates or only one?
Edit. I updated all php files to 644 and scripts seem to be working. I went ahead and setup WD to upload from my station and got the "success" message when I tested, but still not seeing my station conditions, just the sample conditions. I think I need to provide clientraw.txt path in settings? If so, do I fill out the boxes in the WD pic below
(https://uploads.tapatalk-cdn.com/20190129/f0137aaa1005ecdea19178a92544dfbe.jpg)
Post by: jzinckgra on January 29, 2019, 05:37:51 PM
can someone tell me why I am getting this error:
Warning: array_key_exists() expects parameter 2 to be array, null given in /home4/jzinckgr/public_html/pwsWD/w34_livedata.php on line 305
at this link: http://www.weather911.net/pwsWD/index.php
Post by: NorCal Dan on January 29, 2019, 07:47:54 PM
Did you hand edit any of the files included with the distribution?
Also, your page footer shows:
  Data Source: Clientraw n/a    Hardware: Davis VP2 Pro
Double check your path setting in easy setup to your clientraw file...
Post by: wvdkuil on January 29, 2019, 08:15:35 PM
The real error is Warning: file_get_contents(..clientraw.txt):
So there is no data to be read, if you meant that clientraw.txt is in the root is should be  ../clientraw.txt
But that is not correct either as http://www.weather911.net/clientraw.txt  does not exists (404 error) or can not be read.
When there is no data at all, all kind of errors and warnings  can occur. Also the array_key_exist which was checking if a certain field existed.
So for now please reset the location of clientraw.txt to "./demodata/clientraw.txt" then there will be no errors messing things up.
Then you can change ONE setting at a time => save after every change => test => only continue when all remains OK
Post by: jzinckgra on January 29, 2019, 08:18:25 PM
That's where I'm confused. WD generates a clientraw.txt file right? I assume this gets uploaded to my host, but I can't find the file and thus the path to direct to
Post by: wvdkuil on January 29, 2019, 08:24:02 PM
There is far far to much data that WD can generate and upload. There is a youtube movie and a wiki about what to select and how to upload.  Then WD uploads only what you want/need.
Post by: Weather Display on January 29, 2019, 09:28:01 PM
you can set in WD to create and upload the clientraw.txt file
see under control panel
webfiles/web page setup
real time ftp setup
Post by: NorCal Dan on January 29, 2019, 11:39:56 PM
Looking much better now...
Post by: jzinckgra on January 30, 2019, 12:52:40 AM
Making progress: http://weather911.net/pwsWD/index.php
Can get temp, barometer and webcam image to work, but not seeing any wind data or local forecast, current conditions. It's still showing demo for those. When I open the wuweatherupdate.txt file, it is blank. Do I have to use darksky for conditions and forecast?
Post by: jzinckgra on January 30, 2019, 02:14:21 AM
I never had an API key from WU so I think that explains why the text file is blank. Wondering if I'll be able to get one after Feb 15. Seems like a lot up in the air.
Is there a way to use WD to provide 5 day forcst instead of using darksky or metar? I see an option in settings if I'm using clientraw, but not sure where to get the actual frcst file info from. Is it WD?
Post by: wvdkuil on January 30, 2019, 08:43:14 AM
All uploaders to WU should be able to get a NEW-API-key.  But what they can retrieve and if there will be scripts to use the key is unclear.
Quote
The forecast can only come from DarkSky at the moment. You need a free key for that. The limits are also very generous, 1000 calls/day
The current conditions can come from DarkSky, using the same API-key
Or from METAR using another free key
Or WD can read the METAR for you and the clientraw.txt will contain that information.
Quote
Success, Wim
Post by: jzinckgra on January 30, 2019, 11:31:58 AM
All uploaders to WU should be able to get a NEW-API-key.  But what they can retrieve and if there will be scripts to use the key is unclear.The forecast can only come from DarkSky at the moment. You need a free key for that. The limits are also very generous, 1000 calls/day
Or WD can read the METAR for you and the clientraw.txt will contain that information.Success, Wim
Thanks wim. Do you know why wind data is not populating?
Post by: wvdkuil on January 30, 2019, 12:27:26 PM
Permissions problem
jquery.js:1 GET http://weather911.net/pwsWD/wind_gust_block.php?_=1548851151654 500 (Internal Server Error)
It works OK when started with http://www.weather911.net/pwsWD/w34_module_test.php
Post by: jzinckgra on January 30, 2019, 04:03:48 PM
Permissions problem
Got it all fixed. Looks good. Just need to get the historical data working so I can see the trends. I setup mysql db on my server, but do I import the util SQL file from pwsWD? Thanks !
Post by: jzinckgra on January 30, 2019, 08:55:25 PM
Couple other questions:
1. why does dark theme not stay dark all the time? I notice in my web browser that during refresh it changes to the bright theme, then I have to back and switch it again
2. If I make my link (http://www.weather911.net/pwsWD/?theme=dark) public, how do I remove the "Home" and "Menu" buttons at the top left?
3. Can I use a tablet to display the above link and have it display in landscape mode, similar to desktop appearance?
Post by: jzinckgra on January 31, 2019, 01:42:31 AM
Still can't figure out how to setup historical data. Am I supposed to setup the mysql settings in WD as well as the database and table setup on my ftp server?
Post by: NorCal Dan on January 31, 2019, 02:55:04 AM
What historical data are you looking for?  I've looked at your site and I'm trying to figure out what historical data you are missing...
Post by: wvdkuil on January 31, 2019, 08:01:03 AM
In easyweather you define the most used theme, in your case "dark". If a visitor changes that to light, that temporary change is stored in a cookie in his/her browser.  Some users set the use of cookies in their browser to false, so the temporary setting is not kept between refreshes
Quote
You can not do that with a setting. Only by changing the scripts themselves. Be aware that all other links to menu items are lost then also
Quote
It should always display exactly the same way as on a desktop when you hold the tablet in landscape mode. It can switch to "phone mode"  when holding the tablet vertically. There is a minimum width for phone-type-devices, below that width only the important blocks are shown one below each other.
Still can't figure out how to setup historical data. Am I supposed to . . . shortened
With "historical data." do you mean: the graphs?  They get their data either from your own WU data.  Or from the data-table on your webserver.
Using the webserver to store historical data correctly, you should also run the cron-jobs: every 10 minutes plus just before and just after midnight.
Storing the information in the database-table and generating your own daily, monthly and yearly .csv files is described in:
http://wd34.weather-template.com/documentation/WDapi-stationcron-2019-01.pdf
http://wd34.weather-template.com/documentation/WD34-SQL-2019-01.pdf
P.S.  Now  your scripts seems to work, you should install the updates also.
http://wd34.weather-template.com/  ==> Downloads  ==> Third row Updated scripts up to 2019-01-19
Post by: jzinckgra on January 31, 2019, 09:01:56 PM
In easyweather you define the most used theme, in your case "dark". If a visitor changes that to light, that temporary change is stored in a cookie in his/her browser.  Some users set the use of cookies in their browser to false, so the temporary setting is not kept between refreshesYou can not do that with a setting. Only by changing the scripts themselves. Be aware that all other links to menu items are lost then alsoIt should always display exactly the same way as on a desktop when you hold the tablet in landscape mode. It can switch to "phone mode"  when holding the tablet vertically. There is a minimum width for phone-type-devices, below that width only the important blocks are shown one below each other. With "historical data." do you mean: the graphs?  They get their data either from your own WU data.  Or from the data-table on your webserver.
In this link http://wd34.weather-template.com/documentation/WD34-SQL-2019-01.pdf, it says to import the file w34_util_weatherstation_mysql. I don't have that file in pwsWD. I only have w34_util_weatherstation_sql. I can see my table has been created in phpmyadmin but it is empty. In WD when I run mysql, it says "no database" selected. So I selected the database, but the List of Tables field is blank, so I can't select "weatherstation" as the table. See pic.
Post by: niko on January 31, 2019, 09:19:58 PM
@jzinckgra: Your screenshots would be easier to capture/post and a lot easier to read if you use the Windows Snipping Tool (https://www.digitalcitizen.life/how-use-snipping-tool)* which is included in Win 7/8/10. Also .png is usually a better format to use for graphical pages than .jpg which uses data compression optimized for real photographic images.
* Now called Snip 'n Sketch in latest Win 10 I'm told...
Post by: Weather Display on January 31, 2019, 09:45:32 PM
just hit the prtscr key on your keyboard
then paste into good ol windows paint program
and there you can clip and save :)
Post by: jzinckgra on January 31, 2019, 10:02:14 PM
Is this better? I think my 1st pic is more readable. Anyways, any thoughts on my questions? Thanks.
Post by: bitsostring on January 31, 2019, 10:16:35 PM
Is this better?
No! Snipping Tool is in Windows Accessories in the list of apps.
Post by: niko on January 31, 2019, 10:21:06 PM
No. It's beause the image is shrunk down very small on a big canvas (the white area), I'm not familiar with using paint so I don't know how that occurs :dontknow:
Post by: Weather Display on January 31, 2019, 10:36:17 PM
not sure why you are trying to use WD's mysql program?
it wont be able to update the weather34 mysql data if that is what you are trying to do...its not intended or needed to do that
Post by: jzinckgra on February 01, 2019, 12:16:21 AM
Brian,
In easyweathersetup, under historical data: "Which script will load the weather-data to your databse?" Do you know if I select "stationcron job will do database load" or "Wdapi script will do database load"
Post by: Weather Display on February 01, 2019, 12:48:49 AM
hopefully wim can answer that
you certainly do not try and use the WD mysql program
the mysql table will not be compatible at all
Post by: wvdkuil on February 01, 2019, 07:46:11 AM
Brian,
To load your data to the sql-table on your server you use a script which runs 24/7 at a fixed interval, say every 5 or 10 minutes.
You can choose either of the two:
If you  use WDapi you can use that one. A small drawback: if you are uploading very fast, f.i. every 5 seconds, the table will grow rapidly.
If you use the 10 minute station-cron you can use that one. That is the valid choice for clientraw upload also.
Just before midnicht the second cron will calculate the high-lows of today and store a line with those totals in the Yearly and Monthly .CSV files.
To clean the daily sql-table the third cron job will delete all rows from the sql table just after midnight.
To use all, this the PC with WeatherDisplay should run 24/7 and not be restarted during 11:45 PM and 00:15 AM as some users tend to do.
Post by: jzinckgra on February 01, 2019, 01:06:58 PM
I thought I had this figured out:), on my popup temp block, my timestamp for most recent temp is incorrect. The X-axis reports the wrong time.
http://www.weather911.net/pwsWD/index.php (http://www.weather911.net/pwsWD/index.php)
Post by: wvdkuil on February 01, 2019, 01:21:58 PM
I thought I had this figured out:), but my pop up graphs are not being updated. If I run the following script I get this: https://www.weather911.net/pwsWD/w34_cron_stationcron.php (https://www.weather911.net/pwsWD/w34_cron_stationcron.php)
Google is your friend. Search for
Code: [Select]
Connect failed: Access denied for user 'Jzinckgr_weatherstation'@'162.144.12.159' (using password: YES)Some answers point to the privileges again:
https://stackoverflow.com/questions/47667204/access-denied-connecting-to-mysql-with-php
Maybe your Database is not at address 162.144.12.159  Probably that is the ip-number when you look to the database from your home.
The scripts run already at your server, so most of the times it is "localhost" or sometimes "127.0.0.1"
But as I have no experience with your hosting company I am not sure what the problem could be or how your settings should read. Sorry, for this someone else has to answer these questions.
Succes, Wim
Post by: jzinckgra on February 01, 2019, 01:23:40 PM
Code: [Select]
Succes, Wim
I got it. I had stationcron doing the uploads and not WDAPI. Works now, thanks.
Post by: jzinckgra on March 11, 2019, 12:15:28 AM
I'm using an Amazon fire tablet to display my template and the temp is not auto refreshing. Everything else does but temp. Any ideas?
Post by: niko on March 11, 2019, 02:32:59 AM
What browser? The bitsostring template site (inc. temp block) updates OK in Chrome on a Fire HD 10.
Post by: Weather Display on March 11, 2019, 02:36:21 AM
I left the page open and it did update
but the graph shows the temperature is stable at the moment
