I made a wxlocal file and with .setup.control panel.customise internet file creation and upload
i started the creation on 30 minutes and the upload in 30 minutes.
but I do not see the upload.
stupid me again I believe, but what to do.
that transitional message there means that the file is still being uploaded (ftp’d), and has got stuck…
the next update should fix it
it would seem that your ISP/ FTP/web server /internet connection is to blame, and not weather display
it wont be what you did…
unless you unticked to use passive mode when its needed…or try ticking passive mode in the connecitons setup, maybe its now needed by your ftp server
Hi everyone who are you me till now helped.Much word of thanks you behind your selfsacrifice.View please on mine new website,which yet isn’t quite completed,but yet only already are there a little something see.Only thing what me yet does care,why no updates mine screenshot.You can me please advise st. to what I don’t have where up there fabulous programme WD which gives me every day very busy.
200 Type set to I
CWD
501 Invalid number of arguments.
141: 501 Invalid number of arguments.
TYPE A
200 Type set to A
yes
that points to a break down in communications
with the 2nd ftp setup…
(which is uploading the wx5.html file)
try now having so much happen all at once
then you have this
CWD pocasi
550 pocasi: No such file or directory
141: 550 pocasi: No such file or directory
Checking for next FTP agenda…
there are 2 more things to do
Doing ftp upload
i.e your remote directory is not correct , you need to fix that
Hallo Brian I I appreciate your focus about me.Wxl5html is that set what send round webmaster ofocial website of my cities(Pocatky),CWD at all innocent what is the meaning of,remote directory you felt tip- I don’t know which distant directory you have in view.? That what I send on website Pocatky? I have to about your counsels think.Make o.s . heard evening.Now I have to to work. Thanks Jirka
Brain is trying to explain that you login on a ftp-server (ftp.jirkalina.aktualne.cz), and you try to change to the directory “pocasi” on that server (the remote directory), but that directory isn’t there (according to the ftp-log).
Time/date:22:01:13 7.7.2005 Logging onto FTP server…ftp.jirkalina.aktualne.cz
Connecting to FTP server.
Connected.
220 ftp server ready Ok, you have found the ftp-server (and are connected). USER=****
331 Password required for jirkalina.aktualne.cz.
PASSWORD=****
230-Access granted for jirkalina.aktualne.cz. Ok, you’re logged in.
Last login on 2005-07-07 21:50:05 from 193.165.78.194(193.165.78.194).
230 Quotas: using 4260.00 of 50000 KB (8.52% used)
TYPE I
200 Type set to I CWD pocasi
141: 550 pocasi: No such file or directory Not ok, can’t change to directory.
[quote author=chow link=topic=9926.msg73076#msg73076 date=1120797329]
Connected.
remote directory is the directory not on your PC but on the FTP server
you have it set as pocasi
but that is wrong
(and you may not even need one set at all)
Brian,I really I don’t know what there is wrong.I send screen capture(enamel)where you see how I have adjusted general FTP and that sending data works you see on print that is of in weather forum.Me at last managed everything disperse to my data leaved on 2snd server (pocatky website) and now me say that it is a wrong way about .I that at all I don’t understand.If there must be remote directory,I can them say to me there some establish,but as I asked oficial Pocatky webmaster he told me that there remote directory isn’t and doesn’t need to no be.Jirka
ok, i see there is no remote directory, in your screen shot,but try clicking on the set button…
note it should not stop the uploads (unless you have set to not upload if an error with the remote directory)
is that remote directory correct for your web site?
if so, then leave that there…
if not, then correct that…
but it seems like its being used for the general ftp remote directory for the 2nd ftp server to use?
