since it is raining the first time I installed that new custom tags, I had a chance, testing it today:
I noticed there is something wrong with that tags: :?
%leafminlast10min%: there was reported a time of 11 minutes (the maximum minutes could only be 10)
leafminlast60min%:
that tag reports always the same as %leafminlast10min% (I’ve never seen more minutes - it should do up to max 60)
Please could you check that issues for me?
Thanks a lot!
could you please find some time for checking that?
(I would like testing both - this issue and the ftp redial issue on saturday)
Thank you very much!
up - only for not beeing forgotten
sorry, but i am away this week, and so you will have to wait a week for this feature that you want (that most likely very few people would use though (but i guess that is beside the point))
just about midnight here, had a quick look with remote connection, and i have found and fixed the 60 minute tag
will upload a new 10.27c full install now
you are great, Brian.
Did you also found the bug in the 10 minutes tag (11 minutes are reported - max 10 minutes theoretically possible)?
Thank you!
ok, next update of wd should be ok
its like counting fenceposts and the count of the gap between the fenceposts, problem,.,that was the problem
