Author Topic: a lot of rain  (Read 4153 times)
Offline aardvark
  • Des Moines, Iowa
  • Des Moines, Iowa, USA
a lot of rain
« on: July 04, 2005, 02:48:04 PM »
about 6 am we had 1.93 of inches fall within a 10 minute  which figurd out about 10.29 inches per hour.  Now that should be about right..for the year..
No wind, but it sounded like hail against the windows.  only some flowers of the wife's are flat.  sounds like a project for this morning to avoid dishes...
Davis VP2 Plus; 24h  FARS; Extra Temp Humid sensor (2); Extra Temp Station (2); Soil Moisture/Temp Station;Weatherlink IP;USB; MAC Mojave;https://www.weatherlink.com/embeddablePage/show/1c484adbfa914d1aa10a58ad53ccd563/summary
  • Davis VP2
  • New Zealand
    • Weather Display
Re: a lot of rain
« Reply #1 on: July 04, 2005, 07:47:37 PM »
thats alot of rain in 10 minutes!
Offline aardvark
  • Des Moines, Iowa
Re: a lot of rain
« Reply #2 on: July 04, 2005, 07:53:59 PM »
that was my thought this morning.  I went out and checked the rain bucket to see if something might have blocked the funnel then allowed a lot of water  to enter in a hurry, but it is clean and so is the area around the tipping pan.   Of course the rain was short lived  and we don't normally have that amount.
However, there are parts of Northern Iowa that get about 3 to 4 inches sometimes, hence a lot of flooding of the farm fields and small creeks,  which in turn empty in the Des Moines river and flow this way,  but I am up on the higher ground.  If it floods up here, Noah will need to build that ark again.
Offline cyclone
  • Cyclone
  • Mareeba, Queensland, Australia
    • Gorge Creek Orchards
Re: a lot of rain
« Reply #3 on: July 04, 2005, 08:43:21 PM »
WOW  8O
Thats 49mm in 10 minutes, which is 294 mm per hour   :o :o
Do you have a screenshot of the realtime graph ?
Cyclone
www.gorgecreekorchards.com.au
Vantage PP-Leaf Wet, Soil & grass Temp. & Soil Moist
Lightning Tracker-Nexstorm, Noaa 137mhz
U2100-online radio scanner - EFM 100
Offline aardvark
  • Des Moines, Iowa
Re: a lot of rain
« Reply #4 on: July 04, 2005, 09:42:19 PM »
I generated some right away,  two are with Wdisplay and the other is with Wlink on the rate.
I am going to have these available, but I need the disk space so if they have gone the way of the electron...   I could email them.  Oh boy, large downloads.
http://home.mchsi.com/~weatherdata/rain3.jpg
http://home.mchsi.com/~weatherdata/rain1.jpg
http://home.mchsi.com/~weatherdata/Rain2.jpg
Offline hydrowx
  • Bill
  • Northeast Illinois USA
    • Goose Lake Weather
Re: a lot of rain
« Reply #5 on: July 04, 2005, 09:51:27 PM »
Curious to know if you have a manual type rain gauge that you compare with the Davis tipping bucket? With an intensity like that it was bound to underestimate the total. This is not a fault with the Davis but just an inherent problem with tipping bucket gauges in general...they just can't "keep up" with the rain at those rates.
Bill
Davis VP2+
Offline aardvark
  • Des Moines, Iowa
Re: a lot of rain
« Reply #6 on: July 04, 2005, 09:58:15 PM »
Actually. no .. I checked it with a station in West Des Moines, Adel and Van Meter who all reported similar amounts.  I also was awake at that time and it was very intense.   I could hardly see the end of the driveway,  it was as though someone had a fire hose aiming directly down. Ok some big guy or gal with a bunch of angels....
I also checked the funnel and pan to see if some debris had been in the funnel and let go a bunch of water in a hurry and it is clean  all the way.  I am going for that this happened.   We just had a bunch of rain in a hurry.
  Probably caused by that guy in Elgin IL. doing the rain suggestion I gave him a while back ( I know about paybacks)
Offline hydrowx
  • Bill
Re: a lot of rain
« Reply #7 on: July 04, 2005, 10:58:11 PM »
I'm not trying to dismiss the total as it is likely that you may have had a bit more :o than that due to the intensity. Several years ago I had a good 6 hour rainfall and my tipping bucket measured 5.85 inches when in fact the total for my manual read rain gauge was 6.5 I believe. In any case, those types of rains don't do a lot for recharging the soil moisture as it just falls too fast to infiltrate but they're great fun to experience provided your sump pump doesn't quit. :( Good thing you live on higher ground! Now send some of that our way...but over a nice 12-24 hr duration.
Bill
Davis VP2+
Offline aardvark
  • Des Moines, Iowa
Re: a lot of rain
« Reply #8 on: July 04, 2005, 11:07:34 PM »
we don't have a sump which is nice.
I have talked with mother nature and she or he said that it will go you way some day.   Kind of like social security plans
