Author Topic: What kind of map should I use with MML?  (Read 8956 times)
Offline administrator
  • Administrator
  • Blackpool, UK
    • Weather-Watch.com
« on: July 03, 2005, 10:09:38 PM »
You must use a Mercator Projection map for the stations to be positioned correctly. Other types of map projection are not supported. The map must be in JPG format (but not progressive JPG).
The map image will be automatically re-sized to fit the MML display, but don't make your maps too large otherwise they will take a long time for users to download. It's also better, but not essential, to create your map with the same number of horizontal and vertical pixels, i.e. as a square image.
« Last Edit: July 31, 2005, 09:49:25 PM by administrator »
Chris
Weather Forum Administrator
