Author Topic: Suggestion for the desktop mml  (Read 1991 times)
Offline broadstairs
  • Stuart
  • Broadstairs, Kent, UK
    • Broadstairs
« on: June 29, 2005, 08:42:34 PM »
Could the standalone desktop MML be changed to load the maps from the same dir on local machine as the config file? Would help when one's web server is down (like mine is at present). Would also make it easier for testing as maps could be changed without having to upload and overlay live ones.
Offline Softvark
  • UK
    • The weather in Colchester
Re: Suggestion for the desktop mml
« Reply #1 on: June 29, 2005, 10:06:08 PM »
You should be able to do that anyway. As it's running locally you can put a relative path or a local drive path into the mmldesktop.xml and it should work.
Julian
Offline broadstairs
  • Stuart
    • Broadstairs
« Reply #2 on: June 29, 2005, 11:25:09 PM »
Silly me.. :oops: :oops:. you are quite correct using file:///e:/Web-SSI/WeatherDisplayLive/mml/map1.jpg or whatever you file is wokrs just fine....
