Is there a possibility of an automatic redailing of the FTP after some minutes (say 5 or 10 minutes later), if the line was occupated?
It would be great, because I’ve only an analog telephone line here and so often data cant be transferred when telephoning …
Maybe that could be done in a future version?
It would be a wonderful innovation.
Many thanks!
wd should try again if busy, but 1 minute later…and then again a minute later, etc
set the number of redial attemps if line is busy to greater than zero in the connections setup
Where could I find that setting exactely?
I think at the moment I have tomatoes on my eyes #-o
Thanks!
connections setup, in the ftp/internet setup, via control panel
automatic redial of ftp does not work. I set the nubers of redail to 10.
reported in ftp log protocol: *** now anser* - and thats it .
please help.
Thank you!
i do not have it checking for no answer…which is a problem with your ISP not answering the call
i would need to know exactly what was reported in the ftp log, i.e a copy/paste…
At the moment I am not at my weather PC.
I’ll send you on saturday the ftp log protocol
Thanks!
Biran, here is the log report you asked for:
list of files uploaded*
Start Time/date:18:58:07 25.06.2005
Starting to Dial Connection: eTel
Modem change status, # 1
Initializing…
Modem change status, # 2
Modem change status, # 3
Modem change status, # 4
Disconnected
ERROR: Keine Antwort. at time/date 18:59:15 25.06.2005 agenda item:
Will disconnect regardless flag is set…
hope that helps.
thank you!
is that ftp log protocol helpful for finding a solution?
cheers
sort of…
how often does the busy line signal occur for you?
nearly daily (1-3 times)
I am uploading/sending weather data every hour to our broadcasting enterprise and to the national weather service.
ftp and telephone is using the same line - unfortunately there is no other technical solution possible on the side of the telecom enterprise here
ok, then thats german for there is no answer
i have added to check for that now
try this new ftpupd.exe verison:
http://www.weather-display.com/uploads/Ftpupd.zip
Fine - will test in the next few days.
Thank you!
Hi Brian, it does not work - here is the ftp log protocol:
Start Time/date:14:25:06 03.07.2005
Initializing…
Disconnected
ERROR: Die Telefonleitung besetzt. at time/date 14:25:19 03.07.2005 agenda item:
that means ERROR: line is occupated. at time/date 14:25:19 03.07.2005 agenda item:
well that is a different error message than before, and so i need to check for that too
(it will be a bit of a moving target (nothing is as easy as you think))
Brian, no stress with that at the moment
next chance for me testing is saturday…
I will let you knowthe result …
Thanks!
