Author Topic: erratic comms/temp after upgrade to 9.23e  (Read 4268 times)
stevefnz
  • Guest
« on: October 30, 2002, 07:11:31 AM »
hi,
anyone had any probs like this - just upgraded from 8.2?? ish to 9.23e and the temps ex the Davis WMII are appearing and disappearing - the highs are showing -100 and low 1000 !
i also note the cloud base is higher than i've ever seen it and the wind direction is missing from the web dials page
it seems like the comms are erratic - the davis setup page fails to show date & time from the station
i've checked the station with the old davis software and comms all ok
is there any new settings i need to set ?
thanks
stevefnz
  • Guest
« Reply #1 on: October 30, 2002, 07:45:58 AM »
further testing -i think i've got no comms to weather display - all the graphs are flat from the upgrade time and the data quality and received are always red
stevefnz
  • Guest
« Reply #2 on: October 30, 2002, 08:14:24 AM »
solved by resetting com port in WD - note reboots did not fix - it appears there may be an issue with something to do with indoor temp - it disappeared off the program display - i managed to repoduce the effect once - the comms then goes dead till you reselect the same port in WD - but i cant reproduce it consistently
anyway i'm up and running again
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #3 on: October 30, 2002, 09:16:23 AM »
Jim Capanos has had a similar battle with the com port not being setup correct.....after a restart
strange one...
keep an eye on it...
