A continuation of this thread: http://discourse.weather-watch.com/t/70595
I’m still seeing the clientrawrealtimeftp.exe program stop working. The 5 minute restart keeps the site from going stale. But it never used to stop like this. This is the last bit of the screen I could grab before a new instance popped up.
Real time Clientraw FTP, vers 10.2
Time/date:5:40:58 PM 8/13/2022
Logging onto FTP server…bismarckweather.net
Connecting to FTP server at 107.180.48.113:21.
OK
Connected.
220---------- Welcome to Pure-FTPd [privsep] [TLS] ----------
220-You are user number 4 of 500 allowed.
220-Local time is now 15:40. Server port: 21.
220-This is a private system - No anonymous login
220 You will be disconnected after 15 minutes of inactivity.
USER=****
331 User [email protected] OK. Password required
PASSWORD=****
230-Your bandwidth usage is restricted
230 OK. Current restricted directory is /
Changing to remote directory /
CWD /
250 OK. Current directory is /
FTP Uploading C:\wdisplay\webfiles\clientraw.txttemp - >clientraw.txttemp
PASV
227 Entering Passive Mode (107,180,48,113,198,254)
STOR clientraw.txttemp
uploaded ok 5:40:58 PM
150 Accepted data connection
226-File successfully transferred
226 0.050 seconds (measured here), 15.34 Kbytes per second
Renaming clientraw.txttemp → clientraw.txt
RNFR clientraw.txttemp
350 RNFR accepted - file exists, ready for destination
RNTO clientraw.txt
250 File successfully renamed or moved
FTP Uploading C:\wdisplay\webfiles\clientrawextra.txttemp - >clientrawextra.txttemp
PASV
227 Entering Passive Mode (107,180,48,113,197,12)
STOR clientrawextra.txttemp
uploaded ok 5:40:59 PM
226 0.052 seconds (measured here), 62.58 Kbytes per second
Renaming clientrawextra.txttemp → clientrawextra.txt
RNFR clientrawextra.txttemp
RNTO clientrawextra.txt
FTP Uploading C:\wdisplay\webfiles\clientrawhour.txttemp - >clientrawhour.txttemp
PASV
227 Entering Passive Mode (107,180,48,113,197,54)
STOR clientrawhour.txttemp
226 0.052 seconds (measured here), 54.11 Kbytes per second
Renaming clientrawhour.txttemp → clientrawhour.txt
RNFR clientrawhour.txttemp
RNTO clientrawhour.txt
FTP Uploading C:\wdisplay\webfiles\clientrawdaily.txttemp - >clientrawdaily.txttemp
PASV
227 Entering Passive Mode (107,180,48,113,197,85)
STOR clientrawdaily.txttemp
226 0.051 seconds (measured here), 39.68 Kbytes per second
Renaming clientrawdaily.txttemp → clientrawdaily.txt
RNFR clientrawdaily.txttemp
RNTO clientrawdaily.txt
PASV
227 Entering Passive Mode (107,180,48,113,198,226)
uploaded ok 5:41:08 PM
226 0.051 seconds (measured here), 15.05 Kbytes per second
RNTO clientraw.txt
PASV
227 Entering Passive Mode (107,180,48,113,195,173)
uploaded ok 5:41:18 PM
226 0.050 seconds (measured here), 15.29 Kbytes per second
RNTO clientraw.txt
PASV
227 Entering Passive Mode (107,180,48,113,197,70)
uploaded ok 5:41:28 PM
226 0.051 seconds (measured here), 15.06 Kbytes per second
RNTO clientraw.txt
PASV
227 Entering Passive Mode (107,180,48,113,198,40)
uploaded ok 5:41:38 PM
226 0.050 seconds (measured here), 15.23 Kbytes per second
RNTO clientraw.txt
PASV
227 Entering Passive Mode (107,180,48,113,196,31)
uploaded ok 5:41:48 PM
226 0.050 seconds (measured here), 15.18 Kbytes per second
RNTO clientraw.txt
PASV
227 Entering Passive Mode (107,180,48,113,195,103)
uploaded ok 5:41:59 PM
226 0.050 seconds (measured here), 15.21 Kbytes per second
RNTO clientraw.txt
PASV
227 Entering Passive Mode (107,180,48,113,197,147)
uploaded ok 5:42:09 PM
RNTO clientraw.txt
PASV
227 Entering Passive Mode (107,180,48,113,197,88)
uploaded ok 5:42:19 PM
226 0.051 seconds (measured here), 15.07 Kbytes per second
RNTO clientraw.txt
PASV
227 Entering Passive Mode (107,180,48,113,198,122)
uploaded ok 5:42:29 PM
226 0.050 seconds (measured here), 15.17 Kbytes per second
RNTO clientraw.txt
PASV
227 Entering Passive Mode (107,180,48,113,196,25)
uploaded ok 5:42:39 PM
RNTO clientraw.txt
PASV
227 Entering Passive Mode (107,180,48,113,196,35)
uploaded ok 5:42:49 PM
226 0.050 seconds (measured here), 15.27 Kbytes per second
RNTO clientraw.txt
PASV
227 Entering Passive Mode (107,180,48,113,198,148)
uploaded ok 5:42:59 PM
226 0.050 seconds (measured here), 15.24 Kbytes per second
RNTO clientraw.txt
PASV
227 Entering Passive Mode (107,180,48,113,196,34)
