Does the Pi version of WD work with Raspberry Pi model 4B, also if it does, can I use the Raspbian OS
thank you.
I suspect it might but I cant gaurantee
so you will just have to try (use the raspberry pi3 version of consolewd)
I am using a RPI3B and was thinking of buying a RPI4 too when my old RPI3 fried up during a nearby thunderstorm, but it runs a completely different OS i heared, so a would be cautious
the OS will not matter, you can run different versions of linux and the same programs will run
its more the CPU type if that is compatible (e.g ARM 64 bit)
