%currentmintemphtml% does not work below 80 f
Seems to be a gap around 80 76 0vernight low is ok but currently it is 80 and not working for the current tag so it is not a problem with the minimum tag nut a gap
Now: 80.3
try a new .zip update
the tempcolor codes do not match the temppannel color bar, it is evening, 64 deg and the #%currenttemphtml% #21E16D; is light green almost yellow, the temppanel color is dark green. over night low of 45 #%currentmintemphtml%; #21E16D; is about a kelly green, the temp pannel is blue going to purple. High was 75, #%currentmaxtemphtml% #FFD600; kind of orange, temp pannel is light green going to yellow.
image/screen shot?
https://weather.scottsworld.info/index.html you can see it live, the temperature is in the left column, just scroll down a little and you will see it. Today temp panel over night low is 40 which is blue and the %currentmintemphtml% is about a teal green color
what scale are you thinking it should line up against?
the one under the temp panel
I will see what I can do and investigate over the coming days
use the latest .zip update so that the scale on the temp panel matches the html colour code scale
Thank you
BTW, I have found this works much better as a background color than the text color. The text as black and the background changes is more visable.
