I’m running a Lacrosse 2310
Here is the start up info.
Starting
Loaded main form
Loaded internet form
Loaded graph form
Loaded settings form
Loaded control form
Loaded view form
Loaded weather station type
Loaded user daily report
Loaded com port
Loaded timer1
Loaded log settingd
Loaded graph setup
Loaded uv/solar
Loaded ws2000
Loaded extra sensor graph
Loaded daily hi/lo
Loaded metar
Loaded new graph
Loaded large display
Loaded dials
Loaded weather dials
Loaded sun moon
Loaded sensor list
Loaded trends
Loaded sun moon images
Loaded moon
Loaded summary
Loaded extra metars
Loaded 3D graph
Loaded energy
Loaded new rain chart
Doing mainform formcreate
Setting program location to: /home/don/Documents/wdisplay/
Creating ini files
Writing exit to ftp ini file
Setting up graph axis
Initiating variables
Setting conditions strings
Finished doing mainform form create
showing mainform
done form broadcast create
hiding splash screen
setting up graphs
finished showing mainform
error: XDG_RUNTIME_DIR not set in the environment.
Note I get a burst of this error until the tty USB0 syncs up
ser_read error Resource temporarily unavailable
That XDG runtime does not show every time it loads unless the system has reloaded.
The data logger shows no errors while running.
Loaded all time records
Loaded units
com port port handle /dev/ttyUSB0 14
#connected OK to com port /dev/ttyUSB0 14
set the comport OK to speed 2400
stage 1 2310 OK
stage 1 2310 OK
stage 1 2310 OK
stage 1 2310 OK
stage 1 2310 OK
stage 1 2310 OK
s
Error shows up after two days running
Restoring the tty configuration
Runtime error 217 at 00000000008410CF
wmr300decodemac: no process found
wmr200decodemac: no process found
wmr100decodemac: no process found
acuritedecodemac: no process found
fineoffsetdecodemac: no process found
cronweatherflow: no process found
cronftpreal: no process found
cronrapid: no process found
usbreaderirox: no process found
usbreader: no process found
Terminated
don@don-P43T-ES3G:~/Desktop/wdisplay$
Another run of the program and it dies again.
Terminated
After another 3 day run it stopped again.
Terminated
Now I did an upgrade to Linux mint 19.2 and reinstalled the program and still get a run 217 error after it had run fine for two days.
Terminated
The failure is consistent.
Terminated
Next after running the program several times I noticed I thought it was still running fine but the clock on the program had stopped while the system clock still ran. Eventually the program dies and I get a run time 217 errors at the same location.
System info
System: Host: don-P43T-ES3G Kernel: 4.15.0-58-generic x86_64 bits: 64 compiler: gcc v: 7.4.0
Desktop: Cinnamon 4.2.3 wm: muffin dm: LightDM Distro: Linux Mint 19.2 Tina
base: Ubuntu 18.04 bionic
Machine: Type: Desktop Mobo: Gigabyte model: P43T-ES3G serial: BIOS: Award v: F7
date: 08/20/2010
CPU: Topology: Dual Core model: Intel Core2 Duo E8600 bits: 64 type: MCP arch: Penryn rev: A
L2 cache: 6144 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 ssse3 vmx bogomips: 13332
Speed: 2000 MHz min/max: 2000/3333 MHz Core speeds (MHz): 1: 2000 2: 2000
Graphics: Device-1: NVIDIA GT218 [GeForce 210] vendor: Micro-Star MSI N210 Geforce
driver: nouveau v: kernel bus ID: 01:00.0 chip ID: 10de:0a65
Display: x11 server: X.Org 1.19.6 driver: nouveau unloaded: fbdev,modesetting,vesa
resolution: 1280x720~60Hz
OpenGL: renderer: NVA8 v: 3.3 Mesa 19.0.8 direct render: Yes
