What file is used to input the days of thunder! I would like to manually add to the monthly detailed climate report. I have seen other posts about this issue.
I don’t know, but I am eager to know if there is a valid reason to know this?
And who counts it? Is it like the question if a tree falls in the woods when there isn’t any one around to hear it, does it make a noise?
I’m being a bit cheeky here, but where is the value, and who determines the accuracy? I have plenty of storms with visible lightning and precip, but no thunder is heard, nor felt.
Just curious.
Dale
its a non editable data file
but I could make it where you can edit the daily counts?
Brian,
If you can make it so I can manually input thunder in Weather Display, that would be great! Since I do not have a Lightning detector.
I have days past that I would like to enter as well.
Martin
