Author Topic: Latest version of WD for Linux 64 bit will not start up / load  (Read 523 times)
Offline cavman35
  • (Linux Mint)
  • Firefox 68.0
 I've been chasing a runtime 217 error and just tried the latest version of WD for linux 64 bit.  10.37 307 to make sure you had not already corrected the bug and I was just chasing my tail. . Up until now the sudo ./weatherdisplay command would load the program. Now the response is  "command not found".  I also tried the 32 bit sudo ./GoWeather.sh and got the same response so it does not appear to work at all.
don@don-P43T-ES3G:~/Desktop/wdisplay$ dir
climatedata.html       cronmysql          cronwucam
climatedatayear.html   cronnestthermostat      cronx320m
cronambientweathernet  cronnetatmo          customclientrawlocal.txt
cronanytw          cronnetatmo2          Deploy
cronaw             cronpurpleair          exitdavisipdata.txt
croncloud          cronpws             getdavisipdata
croncwop          cronrapid          GoWeather.sh
crondaviswll          crontwitterlinuxnew     location.txt
cronformatedemail      cronwdmqtt          rainrecorded.wav
cronftp             cronweatherbug          readme.txt
cronftpavext          cronweatherbugreal      tagslist.txt
cronftpreal          cronweatherflowconsole  usbreaderirox
crongethawkip          cronwetter          wdstartdelay
cronhttpget          cronwindycom          weatherdisplay
cronmimeget          cronwu
don@don-P43T-ES3G:~/Desktop/wdisplay$ sudo ./weatherdisplay
sudo: ./weatherdisplay: command not found
« Last Edit: August 12, 2019, 10:57:00 PM by cavman35 »
  • Davis VP2
  • Chrome 76.0.3809.100
    • Weather Display
Re: Latest version of WD for Linux 64 bit will not start up / load
« Reply #1 on: August 13, 2019, 07:13:04 PM »
that error occurs if you are not actually running 64 bit Linux
this update is only to fix a problem with the Netatmo rain (there is a thread about that)
  • Davis VP2
    • Weather Display
« Reply #2 on: August 13, 2019, 08:44:17 PM »
try also first sudo chmod 777 weatherdisplay   ?
Offline cavman35
  • (Linux Mint)
  • Firefox 68.0
« Reply #3 on: August 16, 2019, 12:07:31 AM »
 An answer to both answers.
First off the system in 64 Bit Mint 19.2
System:    Host: don-P43T-ES3G Kernel: 4.15.0-55-generic x86_64 bits: 64 compiler: gcc v: 7.4.0
           Desktop: Cinnamon 4.2.3 wm: muffin dm: LightDM Distro: Linux Mint 19.2 Tina
           base: Ubuntu 18.04 bionic
Machine:   Type: Desktop Mobo: Gigabyte model: P43T-ES3G serial: <filter> BIOS: Award v: F7
           date: 08/20/2010
CPU:       Topology: Dual Core model: Intel Core2 Duo E8600 bits: 64 type: MCP arch: Penryn rev: A
           L2 cache: 6144 KiB
           flags: lm nx pae sse sse2 sse3 sse4_1 ssse3 vmx bogomips: 13333
           Speed: 2001 MHz min/max: 2000/3333 MHz Core speeds (MHz): 1: 2000 2: 2000
 Next here is how I got it started. Note donít use a ? after the CHMOD command.
don@don-P43T-ES3G:~$ cd Desktop/wdisplay
[sudo] password for don:
don@don-P43T-ES3G:~/Desktop/wdisplay$ sudo chmod 777 weatherdisplay ?
chmod: cannot access '?': No such file or directory
Starting
  • Davis VP2
    • Weather Display
« Reply #4 on: August 16, 2019, 12:47:08 AM »
i did not mean for you to add the question mark literally
it was a question mark as part of the end of that sentence
so the problem was just a exe permission error
I set it to 777 on my end but I might need to use say 755
