I have, today, changed over to saving my own data (rather than using WeatherUnderground) on my website. A cron job is working well.
I have the data to go back to the beginning of August as well as for the whole of 2019 (indeed back to 2011).
I would like to provide access to data for both all of August and also all of 2019. What is the format of the file/s that is/are required? Can I simply add the data what is already there or what will be there tomorrow morning from the running of w34_cron_addtoyear.php and the 10 minute data saved by w34_cron_stationcron.php?
Keith
Carina Weather, Brisbane, Australia
This info may be available already but I was unable to find it.
You can modify the year/month files and your modifications will not be changed by the cron-jobs. They always add an extra line when they are run.
I think it is easier to wait until tomorrow or manually run the w34_cron_addtoyear.php once.
That way you have the header line and one data line already there.
Keith
Thank you for this reminder, I have to add that to the documentation. Will do that after it is clear if WU deletes the .CSV access or not.
