We set a new all time max temp last week, and the e-mail alert was correctly fired off to everyone.
Unfortunately the same alert (but with current conditions) has then been sent out each day since!
I turned off the alerts yesterday, but this morning discovered that the alert had still been fired off at 2 minutes past midnight this morning.
Here’s a copy of the e-mail
******WEATHER ALERT ******
35.7C all time temperature was exceeded !
Time of event was : 12:02 am
Date of event was : 01/August/2019
Current conditions :
Windspeed 0.0 mph
Direction W 277
a simple restart of WD should fix that I would think
but I will look into it
Thanks Brian,
I had rebooted the system a couple of times without success.
I’ll upload this new file and let you know tomorrow if no alerts.
Thanks again
Neil
Unfortunately didn’t even have to wait until tomorrow !
As soon as I loaded up, the weather warning kicked off and wdwarningemail.exe started to execute (which I then killed so the emails didn’t actually go!)
I’ve manually renamed to wdwarningemail-disable.exe in the meantime as a brute force measure - hopefully that won’t upset anything else?
Any other thoughts or suggestions for me to try?
Really would like to re-enable as it’s such an appreciated service.
Many thanks
Neil
