Strange things happens overhere. after a update W10 a few days ago weather-display is nog working anymore with my davis weather station. one of the two leds is green the other red en next to the green led de 0 keeps standing and is not counting anymore…
1 got the latest update of WD even i updated the CP210x driver. but still nothing…
When i did the update a while back, i ended up deleting the driver and rebooting then reinstalled the driver, rebooted and it worked, remember to pull the usb 1st before youre ready to start wd after reinstall, it was all a bit of trial and error.
day month year hour minute temperature humidity dewpoint barometer windspeed gustspeed direction rainlastmin dailyrain monthlyrain yearlyrain heatindex
Doing checking of time zone calculation
Daylight saving in use
Loaded all time records
Connected OK to com port 1
restarting timer
*sending DMPAFT
Asking for archived data download
Davis VP Retrieving data from: day 2 month 8 year 2019
Retrieving data from: hour 7 minute 35
ask for time/date of record…
1 6 1
1 30 2
1 0 3
1 1 4
1 0 5
1 138 6
1 204 7
VP data Date:= 2/8/2019
VP data Time:= 9:32
VP data Time:= 9:33
VP data Time:= 9:34
VP data Time:= 9:35
VP data Time:= 9:36
VP data Time:= 9:37
VP data Time:= 9:38
VP data Time:= 9:39
VP data Time:= 9:40
VP data Time:= 9:41
VP data Time:= 9:42
VP data Time:= 9:43
VP data Time:= 9:44
VP data Time:= 9:45
VP data Time:= 9:46
VP data Time:= 9:47
VP data Time:= 9:48
VP data Time:= 9:49
VP data Time:= 9:50
VP data Time:= 9:51
VP data Time:= 9:52
VP data Time:= 9:53
VP data Time:= 9:54
VP data Time:= 9:55
VP data Time:= 9:56
VP data Time:= 9:57
VP data Time:= 9:58
VP data Time:= 9:59
Weather station type number 31
i can give you the password for teamviewer i’ve you want.
are you sure, as the time that is coming in from the history data is ahead of the time WD was last running
you could try turning off the switch under control panel, data logger
then restart WD and then see if WD gets live data OK
also there is some more debug info you can make available under view, debug info, if you go to setup, advanced/misc in WD and tick to log the raw data
Your baro offset is way too big, it should be the (small) difference between the raw reading and the adjusted reading, not the adjusted value. WD will ignore data if the baro value (>2000) is unreasonable.
