Thank you everyone for responding :).
i have attached different pictures to show what’s going on here:
the current config
what WD shows and what cronweatherflow does. For example the temp shows 10.5C on WD (not being updated since 7am) and the temperature at 6:38pm from WF (20C).
I have unchecked the UDP setting.
The barometer offset was 82 hpa. I set it back to 0.
I see you have set to use weather flow with other station type
under setup, advanced/misc
if you want WD to use all the data from your weather flow station, then you should not have that ticked
un tick that (and the setting to use for lightning counts) then restart WD
Yes, this was the issue. I think I checked these boxes while I was having issues with the pressure. Thank you for that !
However the pressure that is being picked iby crownweatherflow is still the wrong one. How could we solve that? The current pressure asl is 1011.7 and not 935.6.
I am also using WeatherFlow, do not have any offset set for the pressure in WD … but I am at a different latitude @ 48.7969
Have you contacted the people at WeatherFlow? They are quite helpful. You can ask the question in the WeatherFlow Community/forum or send an eMail message to ‘[email protected]’.
Thanks Brian. I am dealing with the issue that way.
Just by curiosity. Why didn’t I have such issues with Davis VP2? Both WF and Davis have tags for sea level and station pressures.
