So far, when WD is started from Terminal, clicking on any of the aforementioned items does not cause crashing.ah that is good news in a way I am not sure what is going on exactly here are you starting it via sudo ./weatherdisplay via the terminal window or just ./weatherdisplay
Starting with sudo ./weatherdisplay.
OK, that is a clue
the sudo commmand gives more privaledges/permissions i.e root access
so I think there is a permissions problem when you try to run it via the icon
it might mean that your Mac Account is not set as administrator?
or
try
going to your Mac Preferences, security and privacy, → privacy, then select full disk access
click on the lock to unlock at the bottom
then use + to add the weatherdisplay app in the applications folder
try that
I was already Administrator for my account so I gave Full Disk Access to WD under Privacy. When WD is opened via the dock icon, it doesn’t crash at minute change but does crash when either Control Panel or Alarm LED is clicked. Didn’t click any of the other interactives. Still stable when opened via Terminal.
Question: is this the version from the normal WD download page (WD Mac 64 bit version)
Yes, it is. News: Started WD from Terminal but after
was there an error message in the terminal window?
No error message at all.
More news re. Build 323, Sept 16 version. When started from dock icon, WD crashed at minute change. When started from Terminal, however, but without setting up, WD stayed open for over 24 hrs. I then registered and set up (no crashing during the process) and it was operating fine but crashed after less than 3 hours. Not sure of the exact time as I wasn’t watching constantly.
Aloha,
Mark
A couple of things that are new (to me, anyway).
WD stays open for a few hours now when started from the dock. It still crashes if I click on a menu item or the Alarm LED. It does upload data from the data logger initially but stops after a while, how long I don’t know as I missed the times when it stopped uploading, But it doesn’t crash because of it.
What is the window named cronwdstartdelay? I just noticed it hiding behind the main window. Does it open every time WD is started? Also, it is blank, nothing is in it.
Aloha,
Mark
any menu item makes it crash do you mean?
does anyone else have that problem?
but if you start it from a terminal window then that does not occur? (run as sudo)
Opened WD to make sure and yes, clicking on the menu items almost always causes crashes. The exceptions I just observed were: a couple of times clicking on Control Panel did not cause crashes. When I clicked on Sun/Moon Coordinates in CP or the OK radio button, WD crashed. When I clicked on the stand alone Sun/Moon Coordinate icon in CP, WD crashed. When I clicked on Quick Graph Selection one time, WD did not crash but when I clicked OK in QGS, WD crashed. I didn’t try to click on all the interactive sites in the main window except for Alarm and when I did, WD crashed. To be clear, all the above happened after WD was started from the dock.
Right now, WD is running after being started from Terminal. Clicking on all the above mentioned items including the interactive areas did not cause crashes except once when I clicked on the temperature gauges. After the one time, clicking on them did not result in a crash.
Aloha,
Mark
so starting from terminal (as sudo?) and WD works OK for you?
its strange that you have to do that as others do not need to do that
Brian, recall mine did the same thing. When I clicked the icon in the dock. It bounced once or twice then did nothing.
Launching from command line (not sudu) worked
Alas, WD opened from Terminal crashed after probably less than three hours. Again, wasn’t watching closely. Recall that crashing happened previously after about
does the 32 bit version work better for you?
Not sure if that was for me or not.
I’m back to 32bit and it works great as always. The above comment was when I tried the 64bit
that was aimed at either of you
what I could do is use the current compiler version to update the 32 bit version and then you guys can test that version
the problem is there is no gaurantee the 32 bit version will work in the future releases of OSX
note also that more users have no problems with the 64 bit version than have problems it seems
Since you can’t guarantee 32bit to work, I would say keep it.
I will try to work on 64bit again. I’m sure there is a newer version of it out there (sept 7th when I tried last). I know i copied the libraries (verified by you). I also verified the latest Silabs driver.
I can’t take my older mac up to Mojave, but will test 64bit on High Sierra (its just under the cutoff date of being supported -mine is mid 2011 cutoff is early 2012)
Last time I was using the 32 bit WD, latest version, it ran fine. I’ve been running the 64 bit version exclusively all this recent time. The way I understand it, Apple will render 32 bit applications unusable under Catalina, so if we want to stay with the prevailing OS, we have to run 64 bit applications. Do you think a malware scanner running in the background might be affecting WD? ClamXAV is running on this machine. There must be some particular configuration of software or alteration of the OS files or something like that causing some kind of bad interaction.
Aloha,
Mark
