Sorry, no problem report or anything else. Is there anything you can think of that I can supply? Any directory, etc.?
what OSX version?
I am running it now 10.14 OSX Mojave
and its not having that problem
OS 10.14.6, iMac Late 2015. I just noticed in the Title Bar …Trial.
new update, been working on some issues that came about with the new compiler
more improvements coming
thanks to the testers for the help!
I was final able to get it up and running. I had to run the script for moving the files multiple times and then the app started up with out crashing.
Every seems to be working as expected.
macOS 10.13.6
Mac mini (2011)
Processor 2.3 GHz Intel Core 15
8 GB 1333 MHz DDR
that’s good news
yeah, the script does need to be better
or I need some better installer method…that installs the files auto
what weather station type?
Davis Vantage Pro2
It has been running with no issues for several days now
Also, I didn’t need to update the SiLabsUSB driver.
It did crash on Monday straight up at 12pm. I think I saw some other post about it crashing at 12pm or maybe it was midnight.
I will let you know if it does it again.
Sean
yes, there is a crash occuring with the fire weather index update at noon, with the 64 bit compiled code that was not occuring with the same 32 bit compiled code which I am trying to fix…its a tough one as it does not do it every time
I don’t know if this help, but at 9am it stop reporting to Weather Underground. It seems to be still up and running thou.
I have hopefully fixed the crash at noon now in the latest update
re wunderground, any errors under view, program event log?
All is see is resetting the warmest day value. But that is for today at 6am
re wunderground
try running the cronwu from a terminal window from where that program is (i.e in the Resources folder in the weatherdisplay.app bundle)
Brian – the noon crash is still there. We lasted two days, but it bombed at noon today. Running a WeatherFlow weather station. Running the 28 Aug version. Am downloading the 29 Aug version and will give it a run …
JP
it should be OK now in the latest update
Build 323 crashes after being open for a few seconds, so no change.
Aloha,
Mark
Is it on the minute change?
The more detailed info u can provide the better
Hi Brian I have had 10.37Mac64 Build 323 Downloaded on 29 August 2019 - 00:39:33
up and running for last 48hrs, without any problems on my
Mac Mini Server running macOS Sierra 10.12.6 http://southwestweather.com/wx/wxstatus.php
BTrip
that is good
