Hi Wim
Unfortunately NSD2013 is failing on me as well. NSLog appears to be much more stable but obviously creates files in a different format to that expected. This is the data format:
NSRealtime.txt - Comma Delimited - Updated with each Strike - Suitable for rapid uploads to be used by javascript routines.
Position Type Name Description
0 int Year yyyy
1 int Month mm
2 int Day dd
3 int Hour hh
4 int Minute mm
5 int Second ss
6 int Bearing Degrees
7 int Distance Km or Mi as Selected
8 int TRAC X
9 int TRAC Y
10 string Strike Type +CG, -CG, +IC, -IC
11 int +CG 1-Yes, 0-No
12 int -CG 1-Yes, 0-No
13 int +IC 1-Yes, 0-No
14 int -IC 1-Yes, 0-No
15 int Strikes Since Midnight
16 int Noises Since Midnight
17 int Close Since Midnight
18 int CG+ Since Midnight
19 int CG- Since Midnight
20 int IC+ Since Midnight
21 int IC- Since Midnight
22 int Peak Rate Per Min Since Midnight
23 string Peak Rate Time hh:mm:ss
24 int Strikes /Min
25 int Noises /Min
26 int Close /Min
27 int +CG /Min
28 int -CG /Min
29 int +IC /Min
30 int -IC /Min
31 int Current Rate Minutes - X below
32 int X Min Strikes User Selectable counter
33 int X Min Noises 2 Min - 60 Min
34 int X Min Close
35 int X Min +CG
36 int X Min -CG
37 int X Min +IC
38 int X Min -IC
39 string Upload Rate Normal or High
40 string Up Time hh:mm:ss (154:08:23 )
41 string Last Strike Time hh:mm:ss
42 int Days Ave Bearing Degrees
43 int Day’s Ave Distance Km or Mi as Selected
44 int 1 Min Ave Bearing
45 int 1 Min Ave Distance
46 int X Min Ave Bearing
47 int X Min Ave Distance
48 int Peak Burst Rate Per Sec Since Midnight
49 string Peak Burst Time hh:mm:ss
50 int Strikes Minutes # of Minutes stored in NSStrikes.txt
51 int Antenna Offset 1 - 360
52 int Distance Units Being Used 0 = km, 1 = mi
Taken from: https://jcweather.us/NSLog.php Data structures…
Any help gratefully received as usual!
Best wishes
Jon
