The title says it all… What could be causing this strange graph layout? The bottom part is missing…
(please see attached file)
I use these graphs on my website, and this has worked fine for years. But since a while, the graphs look like this…
(WD version 10.37S60)
One thing to check is:
Go to Control Panel > Internet File Creation & Upload > File #2 > press “Set” and see what the graph looks like in the pop-up window.
Also on this window, check if have any resizing set, it shouldn’t make a difference but it may do.
Lastly, the version of WD you’re using is quite old now, you’re on build 60 and the latest is build 99, so it may be worth updating to the latest to see if that changes things.
Turned out to be #11 in my case, but nothing seemed out of the ordinary there.
Updated to build 99; problem gone all of a sudden :-k
No idea what was the cause, but updating was the solution.
Thx.
Sorry, it should have been #11 for the three graphs. #-o
Glad the update appears to have sort it though.
