Hi people i have ws1001 clone, i use WD a lot with my old system up to about a year ago then i got lazy because the ws1001 can send direct to weather underground i stopped using WD … but just getting my web server back up and running i thought a great time to get WD to create web pages for me on my server … so i load up WD setup the correct station only to find out that it said the outside temp is 136F wow i live in the UK that’s just silly temp … everything else works on it fine i have tried running easyweather software and that reports that correct temps … i even tried downloading a fresh copy of WD and run it in trial mode but i am getting the same readings 136F … now when i first got the unit over a year ago i did put ambient firmware on there and they just updated there firmware a month or so ago to 2.5.1 but seen easyweather software is getting it correct then i am not sure if its WD causing the issues or something they done in there firmware… anyone any ideas how to get this to work
Thank You
