I am using a meteobridge nano SD. Does that have anything to do with WD not been able to get the correct historical data?
I have a similar issue with Saratoga template as it think is a normal meteobridge and the nano is different because it holds historical data.
Yes, I think I am
Yes live data is ok, What is not working is historical data. The Nano SD has the ability to store historical data. I was able to fix my issue by entering them manually in WD.
Note: I am using WD for specific stand alone pages. The Nano SD does most of my other data. I would love to switch to WD if it can read the historical data from the Nano SD
WD does work OK with history data from a meteohub
but there might be some differences with the Nano
if you could port forward your nano IP and let me know that then I could test here
