The temperature feels Danger Heat is not proper English at least in America dangerously hot would be proper
%weaterdescription%
Its Afternoon,mostly cloudy - Cumulonimbus clouds observed and it feels Danger Heat outside. The temperature has been rising for the last few hours. There is a Light Breeze from the North east
no ^ space
%heatcolourword% goes from
Hot to
Danger Heat should be dangerously hot
currently 109.3
if you go to control panel → summary images & icons and select the “thresholds” tab you will see a button for “set thresholds for conditionscolour.jpg”, click that and a window will open showing the different names for cold and heat thresholds. You can change any of them to what you want. See if danger heat is shown there as I think %heatcolourword% uses those names.
That is not what the color conditions word is saying though, no where does it say heat but it adds that word
32c warm Temperature
38c hot Temperature
42c uncomfortably hot >Temperature <Humidex
42c Extremely Hot Humidex
44c Extreme caution Hunidex
46c Danger Hunidex
48c Extreme Dander Hunidex to it
Ok, my bad, sorry, over to Brian then
I will change that
but you can still edit it as pointed out
FYI it also affects the %weatherdescription%
