WD - 10.37S96 - running in stationless mode connected to VWS data.csv and second instance of WD running connected to WeatherFlow station . Both instances popup the DataBackup dialog each 24 hrs. I THOUGHT I had set each to backup its data correctly but am confused now that these dialogs keep popping up.
what does it look like exactly?
Sorry - Clearly I need new reading glasses! - Attached is the screenshot. When I look at the databackup directory for each instance, the zip backup files are all there, so I’m not sure why thee popups keep happening. The pc is on 24/7
the databack up program should be closing after it has run
not sure why its not closing for you…must be some error happening and its not closing
maybe check permissions on the directory/files?
Each of the installations’ directories and files are owned by computername\Administrators and the owner has FUll Control of all files and directories; in addition the logged in user also has full control of each
The system is running Win 7 Ultimate Service Pack 1 - 64 bit - fully patched via Windows Update
