Not all problems are solved at WU, sometimes new problems arise also.
Your “old” WU.CSV contains data until July 25.
Your new WU-dashboard is missing far more days for July https://www.wunderground.com/dashboard/pws/ILORRAIN49/table/2019-07-1/2019-07-1/monthly
Also the August data is incomplete, missing august 12.
https://www.wunderground.com/dashboard/pws/ILORRAIN49/table/2019-08-1/2019-08-1/monthly
thank you for the script i just did the test actually we found the files txt pr against in my case we return to the starting point ... to go back, just delete the files in the folder "chartsmydata /"? RegardsThe version of the script I posted yesterday, only converts the WU file without adding missing data. So yes, only the available data until July 25 was generated.
The new version (planned for this weekend) of the script reads the WU-api and tries to add missing days. I was glad to test that new script with your ILORRAIN49 data.
Attached the chartsmydata/ folder with all available from the .CSV and the WU-api history.
The only days missing are 2019-07-27 2019-07-28 and 2019-08-12
Unzip the folder and move only the 2019.txt and 2019_08.txt to your website => chartsmydata/ folder.
@ALL
Very strange, it seems that the new data base has it flaws also. There are more and different days missing in the dashboard as in the .CSV
I do need some other wu_ID’s with missing data to test with.
Post or PM me your wuID if you have missing data in the .CSV which, in your opinion, was uploaded correctly to WU in the past.
chartsmydata.zip (7.24 KB)
