I have just installed this latest template and it looks greate
But how to speed up the live update of wind and wind direction data ??
I use lateste WD and its API to upload the text file needed every 5 sec, but still the site is updating like strait after installation, default aprox every 30 sec on the web site ???
The scripts are using the plaintext files from wxsim.
And Ken True’s plaintext parser.
Check the settings in the pwsWD/wxsimPP/plaintext-parser.php script.
hello
i uploaded the latest version of the template http://valdefench57sgz.franceserv.com/pwsWD/index.php
live data running with the WL 2.0 API
for graphs, my setup parameterized with WU
on the other hand the monthly charts are “out” and the annual ones are all stopped at 25; 07.2019 ??
Regards
" [i]The URL you are using has been retired. It will not return reliable data.
If you are uploading data, you have access to the PWS API. You can download data via the API. Go to
There was (maybe still is) some confusion about what the amount shown in the DarkSky file means.
=> SI units are as follows:
==> precipIntensity: Millimeters per hour. (also for UK2 units rain is in mm)
=> A data point object contains various properties, each representing the average of a particular weather phenomenon occurring during a period of time
==> precipIntensity: The intensity (in inches of liquid water per hour) of precipitation occurring at the given time.
So it is now assumed that for a day forecast the intensity is the average for 24 hours in mm, not in inches.
The scripts display the value from the day-record but multiplied with 24 to get the daily value.
[quote author=meteolive57 link=topic=68132.msg549442#msg549442 date=1566221834]
I contacted WU support
the answer :
I had a look at the current documentation, and I agree that the data point objects are all defined in Imperial units - the default. However, it seems obvious that, if you request a response in uk2, you should get UK units returned. So there should be no confusion. I presume this is what you are assuming now.
So what was being assumed in January? I can not see any easy conversion factor.
EDIT: It has been pointed out that July rain ~ 6 x January rain :?
re_thanks for the explanations ok so it is possible to work around the malfunction WU by running cron tasks following the installation instructions of the template? but do you also have to edit the files “34_cron_addtoyear.php” and “w34_cron_stationcron.php”? … for live data I use the WL 2.0 api
thank you in advance
Regards
