I didn’t even notice the different am/pm on my template. I loaded the fixed w34_livedata and now it is perfect. Thankyou everyone!
Well it was working great, Now it’s showing a low of -36.4
[quote author=a55bruce link=topic=68132.msg549000#msg549000 date=1565101570]
Yeah, I found that the data was bad after I sent the post. I was blaming the WU data server, but, the Acurite site show the same bad data.
Now I have to figure out if this just a couple of glitches or do I have a bad temperature sensor??? #-o
[quote author=Mogens link=topic=68132.msg548906#msg548906 date=1564845924]
Today I have sent the following to WU.
Exciting if there is a solution.
Hello
I have a weather station
IDKFREDE2
which sends data to WU.
I have found some mystifications.
When I want to get data for this year here
https://www.wunderground.com/weatherstation/WXDailyHistory.asp?ID=IDKFREDE2&graphspan=year&format=1
stops data by July 25.
If I want to get data for August here
https://www.wunderground.com/weatherstation/WXDailyHistory.asp?ID=IDKFREDE2&graphspan=month&format=1
I get a file with no data.
Data for July 25 as here
https://www.wunderground.com/dashboard/pws/IDKFREDE2/graph/2019-07-25/2019-07-25/daily
says there is no data. This is mysterious as both maximum and minimum values are present.
Year and month data should be used in this template
http://weather.inaogmogens.dk
Can you fix it so I can retrieve my data again?
(I know I have problems with correct temperature display, but shouldn’t that be the cause of these problems?)
Kind regards
Mogens
Yes, the error apparently only applies to some WU sites.
Your problem seems to be quite like mine.
I have not received a response from WU. I probably didn’t expect that either :x But on their forum they write
[i]"Hi, Ul Ke!
This is a problem we know about and have in the queue to address. I hope you will be patient with us while the programmers work.
Thank you!
–Victoria"[/i]
How long to be patient?
I want to use an official AQ station to display the AirQuality in my area so I get a APIkey at this site https://aqicn.org/data-platform/token/#/. I insert the API key in waqitoken field on w34_easyweathersetup.php but I get this error message:
Official AQ sensor station
Problem 55: No AQindex found
Check settings and data
What’s missing?
That can only be answered if I can check the data.
What is the URL to your website?
You should also check if the key you copied to easyweather does not have any spaces before or after the string.
Thank you very much, Wim! I probably copied with a space after the string… Now it works!
You can see: https://vmribeiro.net/pwsWD
Vitor Ribeiro
=D>
hello Wim, in the uv-solar and internal temp box i prefear for the value the big number internal at the figure like the beta release (http://www.tanzaetpunza.altervista.org/pwsTEST2/index.php), is it possible to do that?
thanks, Lorenzo
it is not that easy as those big numbers with their pixel positioning, were removed for the July release to make user changing of the scripts easier.
But i will take a look.
As requested and only of interest for those users running the PWS-Dashboard in an iFrame inside another template or website page:
==> test Leuven Home Weather Station (wf version)
Adding the stripall parameter to the URL removes the header, menu and footer.
Maybe also an option when using a spare iPad as an extra console.
But in that case you will loose the menu also.
w34_index2.php.zip (6.93 KB)
thanks for your interest, it’s not that important, I don’t want to waste your time, thanks anyway, bye
Questions are never waste of time. And all wishes can be added to the “wishlist” topic.
Please test the attached version, after you make a copy of the current script.
uvsolarlux_c_block.php.zip (5.25 KB)
When there is no real weather-alert, most users get a forecast text (from WS or WU) in that alert-box.
There was a PM with the request for a WXSIM forecast text also.
Please for WXSIM users, test this version, after you make a copy of the current version.
The WXSIM forecast texts can be quite long, so the font-size is adjusted based on the length of the text.
advisory_c_small.php.zip (3.61 KB)
Wim, the use of the WXSIM data seems to work well.
How difficult would it be to replace the ‘Weather alert’ header text with something more relevant to the text in the box, such as, possibly, ‘WXSIM Current Forecast’ (just a suggestion).
After replacing some distribution scripts with new scripts you have posted in previous messages, the date and time appearing on the top right corner border is pushed down by about 5-10 pixels.
All these scripts are posted here as a pre-release-test.
As you can check at the screenshot in the message for the WXSIM forecast, the date/time script is also changed.
It now replaces the ?too heavy? “Weather Alert” text.
Another wish/request: “When using my smart phone the server date-time is not shown, can you . . .”
So it seemed better to move the alerts to the left and have the data time in the header of that box.
The content in the box will explain if it is a forecast or a warning or a alert.
Now the menu, and home button plus the C/F switch and clock are all together visible in the top left corner.
Please test this version of the clock script, after making a copy of the current script.
clock_c_small.php.zip (2.36 KB)
thank you so much Wim
I do not get Time and date in header bar
