Hallo Wim,
wanneer ik de template test krijg ik de volgende meldingen.
Warning: file_get_contents(): https:// wrapper is disabled in the server configuration by allow_url_fopen=0 in /home/meteosle/public_html/pwsWD/w34_livedata.php on line 576
Warning: Cannot modify header information - headers already sent by (output started at /home/meteosle/public_html/pwsWD/w34_livedata.php:576) in /home/meteosle/public_html/pwsWD/w34_index2.php on line 88
the solar radiation data are availabe from WU, you already fetch it with your actual data set.
I added the solar radiation graph to w34_graph by
$grphs[‘solar|day’] = ‘|’. ‘|0|’.lang(‘Solarradiation’).‘|’. ‘|0|’.lang(‘Solarradiation’).‘|’.$temperatureconv.‘|’.‘W/m2’. ‘|13|-1|HH:mm|12|||’;
Has anyone used the weewx realtime.txt setup? I’ve tried using it and for some reason my temp drops to 0 degrees at times and my barometer stays at 0.00. Website address is https://klephtic-math.000webhostapp.com/
Problem with max wind|gust block just after midnight when max gust not displayed at all. Checked live data and max gust was 0, so I’m guessing it’s down to the conditional in line 79 of wind_c_small.php
if ($weather['wind_gust_speed_max'] <> 'n/a'
which says, basically, if max gust is n/a (or 0) then don’t show anything. (But I haven’t worked out why max wind time was still showing 14.20.)
Wim, I might have fixed it. I’m using the Cumulus CRT to creat the realtime.txt I changed the setting from loop to archive. I think what was happening is that the Acurite was updating different readings at different intervals which caused the null values. Thanks!!
I have made attempts to change the country flag on my site. USA - I changed the $flag setting in “setings1.php” to “us.svg”, but any time I save the “easyweathersetup.php” it reverts back to the British flag. There does not seem to be a choice in “easyweathersetup.php” for a US flag. Is there another file that I need to change along with $flag in “settings1.php”?
No, no luck. Renamed us.svg to xx.svg (Renamed the old xx.svg first) and changed Easyweather to “Your Country” also changed $flag in wd34settings1.php to xx.svg. Still loads with British flag. Also on numerous occasions when I save Easyweather, it reverts to a different version and my changes are gone.
John, I ran in to the same problem with the flag and couldn’t understand why changing the name to xx wasn’t working. It wasn’t until I tried my site in a different browser that I realized it was a local caching issue.
Well, I thought it was working!! As soon as I open Easyweather and save close it reverts back to UK flag. It is like it is opening an old file. If you have to clear the cache to go into settings that just isn’t going to work.
