It’s great that you want to look at it.
But you must enjoy your vacation.
As I wrote, there is nothing urgent.
Thanks, but for myself and all other WU-template users it needs to be solved somehow.
And rest assured, this is the fun part of this hobby, how to solve this kind of challenges.
I wanted to ask something. I ordered UV and solar radiation sensors for my Davis VP2. Once arrived I will activate in the template the relative section that will indicate the data coming from these two sensors. In the pemplate Demo the UV / Solar box is active but not by trend graphs. I wanted to know if they will ever be implemented and especially if the indication of the ET index will ever be implemented.
It’s just my curiosity
I have installed your new template version at https://www.weatherinharrogate.co.uk/pwsWDjuly/ and I have changed all the settings except the path to the clientraw.txt data and the webcam picture. If I try putting these paths in I get a Wordfence Error on my screen with error 403. The previous version is installed at https://www.weatherinharrogate.co.uk/pwsWD/ and this works fine. I can change the path in the easyweather setup up file and it is okay in this version. I can send you the password.
-------------------------This is what appears on the screen
403 Forbidden
A potentially unsafe operation has been detected in your request to this site.
Generated by Wordfence at Mon, 15 Jul 2019 15:24:00 GMT.
Your computer’s time: Mon, 15 Jul 2019 15:23:59 GMT.
April version: https://www.weatherinharrogate.co.uk/pwsWD/w34_module_test.php => click left bottom box with …/weatherdisplay/clientraw.txt
=> 403 Forbidden A potentially unsafe operation has been detected in your request to this site. a.s.o.
So both versions complain, but the April version works although there is a complaint.
I inserted in the html the link to the webcam in the July version => OK
So these errors seem not to block the working. The Wordfence does not like linking to another folder backwards, i think. But it still seems to work.
Could you please add the correct links to your settings? So that i can see if it works?
The data for the graphs com from WU and there is only UV data available, no solar.
As it is still not clear if and how WU will continue access to out own data, I will start after my vacation with new graphs based on the new WU-api.
The 7 day data contains both UV and solar. There can probably be a meaningful UV-solar graph added.
I do not understand what what you mean with ET-index.
There is a calculated ET-value (Evapotranspiration) when there is a Davis console but not all weather-programs deliver that.
There are requests for soil-moist sensors and extra temp-hum sensors, so the ET-value can be added to the list of new weather-values.
Be aware that the WU-data does not deliver any ET-values as I am aware of.
Use for all these and further “wishes” the special “wishes”-topic => http://discourse.weather-watch.com.new#new
There we discuss the needed enhancements to the template for the next version.
I have put the full html address in for the clientraw.txt file/webcam pic and that works fine, as you say for some reason wordfence allows the old version to work, but not the new July version. I will just leave the full address for the time being. Many thanks for the prompt reply. I guess other people may come across the same issue if they are looking to another folder backwards.
OK thanks
Hallo Wim,
wanneer ik de template test krijg ik de volgende meldingen.
Warning: file_get_contents(): https:// wrapper is disabled in the server configuration by allow_url_fopen=0 in /home/meteosle/public_html/pwsWD/w34_livedata.php on line 576
Warning: file_get_contents(https://meteo-sleen.nl/weather28m/uploadCW/clientraw.txt): failed to open stream: no suitable wrapper could be found in /home/meteosle/public_html/pwsWD/w34_livedata.php on line 576
Warning: Cannot modify header information - headers already sent by (output started at /home/meteosle/public_html/pwsWD/w34_livedata.php:576) in /home/meteosle/public_html/pwsWD/w34_index2.php on line 88
Wat is hiervan de oorzaak
Roelof
Earthquake block displays distance units KMs whether the distance is in km or miles.
P.S. I have already changed units “KMs” to “km” in the attached screenshots of my block.
P.P.S. It can wait until you get back from holiday, Wim
Hello Wim,
the solar radiation data are availabe from WU, you already fetch it with your actual data set.
I added the solar radiation graph to w34_graph by
$grphs[‘solar|day’] = ‘|’. ‘|0|’.lang(‘Solarradiation’).‘|’. ‘|0|’.lang(‘Solarradiation’).‘|’.$temperatureconv.‘|’.‘W/m2’. ‘|13|-1|HH:mm|12|||’;
Best regards
Reinhard
Has anyone used the weewx realtime.txt setup? I’ve tried using it and for some reason my temp drops to 0 degrees at times and my barometer stays at 0.00. Website address is https://klephtic-math.000webhostapp.com/
https://klephtic-math.000webhostapp.com/w34_module_test.php
Left bottom, select the real-time.txt and click List contents
As you will see, the file is nearly empty, with 0 and a lot of NULL values
I am on holiday till July 28, without decent internet. I will check when I am home
Problem with max wind|gust block just after midnight when max gust not displayed at all. Checked live data and max gust was 0, so I’m guessing it’s down to the conditional in line 79 of wind_c_small.php
if ($weather['wind_gust_speed_max'] <> 'n/a'
which says, basically, if max gust is n/a (or 0) then don’t show anything. (But I haven’t worked out why max wind time was still showing 14.20.)
All OK this morning
Wim, I might have fixed it. I’m using the Cumulus CRT to creat the realtime.txt I changed the setting from loop to archive. I think what was happening is that the Acurite was updating different readings at different intervals which caused the null values. Thanks!!
Setting Country Flag -
I have made attempts to change the country flag on my site. USA - I changed the $flag setting in “setings1.php” to “us.svg”, but any time I save the “easyweathersetup.php” it reverts back to the British flag. There does not seem to be a choice in “easyweathersetup.php” for a US flag. Is there another file that I need to change along with $flag in “settings1.php”?
http://scannorthcounty.net/pwsWD/index.php
John
No, no luck. Renamed us.svg to xx.svg (Renamed the old xx.svg first) and changed Easyweather to “Your Country” also changed $flag in wd34settings1.php to xx.svg. Still loads with British flag. Also on numerous occasions when I save Easyweather, it reverts to a different version and my changes are gone.
John
Have you searched for the answer? I think you are supposed to rename us.svg to uk.svg . . .
All you have to do is rename us.svg to en.svg
No other changes are required
