That pwsWD is not the July release. Seems to be the April release.
Always do a full install for the new releases, at least until the December release.
All seems well except the current conditions block.
The sky conditions are current with KPDX metar however, I can't figure out where the other data
within the block comes from and how to correct it.
Larry
The current conditions you selected are from your METAR.
The other part of the information comes from [b]the 1 hour DarkSky forecast [/b]
As there is no API key the old cached information is shown. And that is in Dutch.
Start easyweather-settings.
Enter a DarkSky API-key
Set the DarkSky language to your language
And the DarkSky forecast will be available for the current conditions block.
If all is OK:
Download the latest version from http://wd34.weather-template.com/
Rename your current pwsWD website folder to pwsOLD
Upload the newly unzipped pwsWD folder
Copy the w34-settings1.php from pwsOLD to pwsWD
First run pwsWD/easyweathersetup.php and check all default values, they are blue
Thanks for the help.
Updated to current version.
2 minor issues.
When I click on “nearby” under current conditions, it shows
EBBR instead of KPDX.
When I click on webcam, the larger display is blank.
Larry https://vancamweather.com/pwsWD/index.php
Hello,
I noticed this problem with the UV block, with the translation coming out of the rectangle, can something be done?
Thank you
site: https://stazione.meteosantangelo.it/pws07/
Although the problems are minimized in this version, there will always be translation texts which do not fit. Weather-texts are often more compact in English then in other languages. In this block the room for that text is nearly at its maximum.
If you do not want to change the php script yourself, you should change the translated text and remove the word solare
It is for the visitor clear what the values are anyway.
I have installed this fine template.
My weather station is a WS-1001 clone that sends the data to WU every 16 seconds without using a computer. I have a new API key from WU and get live data from there.
w34_cron_stationcron.php runs every 5 minutes.
But I have some mystifications.
The current data is displayed correctly, but the max and min values for both wind and temperature look mysterious.
It appears that it is always the minimum value displayed for both max and min for temperature. What numbers are displayed for max and minimum wind I cannot figure out.
I selected 1 decimal for temperature display. I also get 1 decimal, but the temperature is always rounded to the nearest whole number, so the decimal always shows zero. (If I switch to Fahrenheit, a decimal will be displayed correctly).
If I use Chrome browser, pop-ups for displaying e.g. “Wind today” fills the whole screen and the close button does not work, so I can only go back to the main screen with the browser’s left arrow. When I use Firefox, it works normally.
Is that something that can be arranged?
There is no rush. The weather is the same, no matter what my weather station reports.
The template can not display more information than WU gives us.
Please check the debug-console here => "weather.inaogmogens.dk"
Second row shows the file-contents as loaded from WU at the left dropdown-box:
“./jsondata/wucom.txt” => last measurement =>current temp = 20 degrees
“./jsondata/wucom_day.txt” => todays high-lows
As you can see the three temp fields contain the same data, 16 degrees
You can check all the (recalculated) values we use in the template right dropdown-box: “Live data values”
I assume there is a small hick-up in the WU data as other stations are reporting normal values at the moment
- I selected 1 decimal for temperature display. I also get 1 decimal, but the temperature is always rounded to the nearest whole number, so the decimal always shows zero. (If I switch to Fahrenheit, a decimal will be displayed correctly).
The temperature WU gives us is without any decimals. That is a huge problem for all users. Also their new dashboard has the same problem.
When you use the F button the template scripts do the recalculation and round it to the 1 decimal you want.
But when loading the data from WU you should better use no decimals for temp.
- If I use Chrome browser, pop-ups for displaying e.g. "Wind today" fills the whole screen and the close button does not work, so I can only go back to the main screen with the browser's left arrow. When I use Firefox, it works normally. Is that something that can be arranged?
I can not reproduce that using Chrome on your website. I myself use Chrome 95% of the time and do all development and testing with it. All graphs should work the same way as they are using the same script and the same pop-up code.
I attach a screenshot of the "Today" graph using Chrome.
QUESTION: Is it the daily-graph or the forecast (4th pop-up) by wind?
Link to templatehttp://weather.inaogmogens.dk
Thanks for using the template, and i will check a few times why your min-max temp values are all equal.
P.S. comparing your weather-values in the WU-uploads with those on your WU-dashboard there are more errors in the upload, also the pressure min-max are both equal to the min value
Temperature without decimals is OK for me. I just wondered.
The mystification with the pop-ups applies to all the links in the bottom of each field, but there is obviously a mistake in my Chrome - I just borrowed my wife’s computer, and it works correctly, so sorry for the inconvenience :oops:
Concerning maximum and minimum issues.
When I test modules that you suggest, I can see that the wucom_yday.txt file, which the program generates, writes minimum and maximum temperatures equally.
It seems to me that part of this file has been copied from wucom.txt in a way I can’t figure out.
However, I can observe that the correct maximum and minimum temperatures and wind speeds can be found in the “pristine” wucom_yday.txt file. As far as I can see, WU has actually sent them correctly.
However, I can observe that the correct maximum and minimum temperatures and wind speeds can be found in the "pristine" wucom_yday.txt file. As far as I can see, WU has actually sent them correctly.
See [http://weather.inaogmogens.dk/jsondata/wucom_yday.txt](http://weather.inaogmogens.dk/jsondata/wucom_yday.txt)
The values on the template you are talking about are from today as generated by WeatherUnderground.
Those values are generated from the database and sent to the website every time the scripts ask for it.
So even if the yesterday values are correct, the todays values were and are incorrect.
You can test that yourself with the link above, just fill in your api-key replacing the [b]_API_SETTING_[/b]
Mogens
RECAP:
I even used another API-key and still the data from July 13 has correct values, from today, July 14, has incorrect values.
Your dashboard shows correct values for today but the api data has incorrect (the same) values for all temp fields and also equal values for pressure.
The time fields show that even in the browser, todays data is from just after midnight. [color=red]obsTimeLocal "2019-07-14 00:04:51"[/color]
So there is definitely a problem with the database at WU, not with a script.
Lets see if it is OK tomorrow, otherwise I have to think about some solution using English units.
You can check my test-wu-website at old link removed https://pwsdashboard.net/
It displays the data correctly as WU is delivering correct data.
For now I have no quick solution.
Correction:
I tried again my wife’s computer and her computer showed the page correctly.
Now I’ve cleaned up my Chrome and it looks like the max and min are currently showing up correctly. I will watch it during the day.
The problem with pop-ups is no longer there either.
Unfortunately, still an inaccuracy.
Early in the afternoon, the temperature crept up above 20 degrees for a short while.
It can be properly seen on the Temp today pop-up.
But maximum temperature is still displayed as 19 degrees.
Ye, I know.
I am on vacation until July 28. immediately thereafter I will have a new version for todays and yesterdays data.
Maybe even earlier, but one has to wait for a hours to check if a solution works also later in the day.
I wanted to ask something. I ordered UV and solar radiation sensors for my Davis VP2. Once arrived I will activate in the template the relative section that will indicate the data coming from these two sensors. In the pemplate Demo the UV / Solar box is active but not by trend graphs. I wanted to know if they will ever be implemented and especially if the indication of the ET index will ever be implemented.
It’s just my curiosity
I have installed your new template version at https://www.weatherinharrogate.co.uk/pwsWDjuly/ and I have changed all the settings except the path to the clientraw.txt data and the webcam picture. If I try putting these paths in I get a Wordfence Error on my screen with error 403. The previous version is installed at https://www.weatherinharrogate.co.uk/pwsWD/ and this works fine. I can change the path in the easyweather setup up file and it is okay in this version. I can send you the password.
-------------------------This is what appears on the screen
403 Forbidden
A potentially unsafe operation has been detected in your request to this site.
Generated by Wordfence at Mon, 15 Jul 2019 15:24:00 GMT.
Your computer’s time: Mon, 15 Jul 2019 15:23:59 GMT.
April version: https://www.weatherinharrogate.co.uk/pwsWD/w34_module_test.php => click left bottom box with …/weatherdisplay/clientraw.txt
=> 403 Forbidden A potentially unsafe operation has been detected in your request to this site. a.s.o.
So both versions complain, but the April version works although there is a complaint.
I inserted in the html the link to the webcam in the July version => OK
So these errors seem not to block the working. The Wordfence does not like linking to another folder backwards, i think. But it still seems to work.
Could you please add the correct links to your settings? So that i can see if it works?
