[s]Did you fill in the link in easyweathersetup?
It still seems to be the default one, including the typo
As the img is only used as a background img the whole pop-up is white, I think.
If there is a valid image I can test further.[/s]
:oops: :oops: :oops: :oops: :oops: :oops:
Use the attached one, with testing just before the self-imposed deadline I commented both possibilities (img or video) in the script.
On my system the only way I can find to return to the main display (without using the browser back button) is by hitting either the home button in the header or from the drop down menu. Clicking outside the pop-up does nothing. Why is there no “X” on the pop-up box?
For those items under Menu Extras that’s exactly right (see reply #18 above). There is an X on all the pop-ups generated on the main page, but you only have to click outside the box for them.
Popups are the graphs, tables a.so. They have no headers and meno of their own, they are “superimposed” on-top of the normal page with the blocks. They always have a X on the left corner as I tested at https://www.shermanctweather.org/pwsWD/index.php
You have to click on the X (or outside the box) to get back to the normal page or to the menu.
Test it, pop-up a graph,
click on menu => pop-up disappears but no menu yet
click again on the menu => menu opens
Extra pages as the menu entries they fill the whole browser window, can therefor have no X, have their own bar with the clock, footer and the small blocks top-row.
You can go to any other page (including the home page) by opening the menu directly.
You can see this behavior better by switching to the dark theme.
Uploaded the July Version and cannot see where to add my webcam address in “webcam_c_block.php”. I see where it says it goes, but not sure where to put it. It says as set with “easywaether”. There was no place in “easyweather” to set the location. Thanks for any assistance. www.scannorthcounty.net/pwsWD/
Not for all as I have to find a simple solution for the extra upload data, that is why I did not include it in this version. Only WD-api (3 TH but no soil) and WL.com (all) have the extra sensors
But one can add a block to w34_blocks.php and manually change the settings1.
When the next beta is available (August) a standard solution will become available also as an update for the normal releases.
It should include correct versions of extra_tmp_c_small.php and soil_c_block plus a soil pop-up. Also all “extra”-scripts should be in easyweather.
Looks OK, but colours are not working?. . . Try putting “This hour: Temperature. . .” on the same line if you want to save a line and show Rain and UVI on separate lines. (URL as left but /pwsnew/: I’ve modified my original w34_util_ccn.php to get UV and colours.)
WD-clientraw has 8 extratemp/hum fields. . . I’m also using a WD customtextout.txt file to get extra upload data.
I know. . .
It should include correct versions of extra_tmp_c_small.php and soil_c_block plus a soil pop-up. Also all "extra"-scripts should be in easyweather.
Meteoalarm.eu alerts display correctly but if there is no alert, the forecast for tomorrow now appears in the alerts box instead. Is this intentional? http://www.collapit.org.uk/pwsWD/
Yes it is.
Explanation: When there is no outside “official” alert and no internally calculated warning, what should we display there?
Earlier versions used a “no alerts” message. But users thought that was a waste of space.
So if there is some meaningful information, like a forecast, that is displayed.
Some users changed the translation from “Weather alert” to “Weather message”, but that is nitpicking.
Thanks for the explanation. I’d suggest prefacing the forecast in the alert box with,“Forecast for tomorrow:”. It was only clear to me that it was tomorrow’s forecast when I looked at the forecasts in the "forecast ahead"pop up but perhaps I’m nitpicking too!!
