Author Topic: HWS-template (WD34) July version available  (Read 23020 times)
Offline wvdkuil
  • Wim van der Kuil
  • Leuven Belgium CET
  • Mac OS X 10.13.6
  • Chrome 75.0.3770.142
    • My PWS at Leuven Belgium Europe
Re: HWS-template (WD34) July version available
« Reply #195 on: August 01, 2019, 08:53:05 AM »
Hi Wim
Under the Current conditions This Hour it has the temp at 30c but the actual temp is 10.7c, I am not sure where that temp is coming from.
http://www.mangawhaiweather.co.nz/pwsWD/index.php
Tony
There are two parts: The top part is, in your case,  the current conditions from WeatherDisplay.
The bottom part (with the 30C) is the current "this"  hour forecast, from DarkSky.
Add a DarkSky key and that information will also be current,
« Last Edit: August 01, 2019, 08:58:23 AM by wvdkuil »
Support & demo PWS_Dasboard  (HWS_template) http://pwsdashboard.weather-template.com/
My PWS at home https://weer.sluispark.be/
And at my daughters house https://www.weerstation-herent.be/
Offline tonyva
  • Mangawhai Heads, Northland, New Zealand
  • Win NT 10.0
    • Mangawhai Heads Weather
« Reply #196 on: August 01, 2019, 11:11:14 PM »
Quote
Thanks Wim.
Thank You
Tony
Weather Dedicated 24/7 HP Dual Core 1.8 Ghz CPU, 2GB Ram
Offline Mogens
  • Frederikshavn, DK
  • Win NT 10.0
« Reply #197 on: August 03, 2019, 03:25:24 PM »
Today I have sent the following to WU.
Exciting if there is a solution.
Hello
I have a weather station
IDKFREDE2
which sends data to WU.
I have found some mystifications.
When I want to get data for this year here
https://www.wunderground.com/weatherstation/WXDailyHistory.asp?ID=IDKFREDE2&graphspan=year&format=1
stops data by July 25.
If I want to get data for August here
https://www.wunderground.com/weatherstation/WXDailyHistory.asp?ID=IDKFREDE2&graphspan=month&format=1
I get a file with no data.
Data for July 25 as here
https://www.wunderground.com/dashboard/pws/IDKFREDE2/graph/2019-07-25/2019-07-25/daily
says there is no data. This is mysterious as both maximum and minimum values are present.
Year and month data should be used in this template
http://weather.inaogmogens.dk
Can you fix it so I can retrieve my data again?
(I know I have problems with correct temperature display, but shouldn't that be the cause of these problems?)
Kind regards
Mogens ěrsted
Offline hcorrin
  • Ballaugh Isle of Man GB
  • Win NT 10.0
  • Mozilla compatible
    • Ballaugh Weather
« Reply #198 on: August 03, 2019, 09:27:10 PM »
normally re uploading the data to WU would sort it
you do not say what weather station you have or what software you use
Offline Mogens
  • Frederikshavn, DK
  • Win NT 10.0
« Reply #199 on: August 04, 2019, 06:44:12 AM »
Data is present at WU - except for July 25.
See
https://www.wunderground.com/dashboard/pws/IDKFREDE2/graph/2019-08-4/2019-08-4/daily
Scroll down and click "Previous"
WU simply does not send data on request.
WU knows both weather station and software.
Click the round "i" next to "IDKFREDE2" at the top of the same page.
« Last Edit: August 04, 2019, 06:51:43 AM by Mogens »
Offline wvdkuil
  • Wim van der Kuil
  • Mac OS X 10.13.6
« Reply #200 on: August 04, 2019, 08:01:58 AM »
See
This is not a HWS or script problem on our side.
This is a problem on the WU/TWC site where the two databases, old-WU and new-TWC are not always correctly synchronised.
Check these and  other discussions on the wx-forum:
https://www.wxforum.net/index.php?topic=37137.msg386502#msg386502
https://www.wxforum.net/index.php?topic=37512.0
and on the WU forum:
https://apicommunity.wunderground.com/weatherapi/topics/huge-amount-of-data-is-missing-on-pws-dashboard
I am 100% sure that they will solve the missing data for the API-json scripts corrected as they need that to populate the dashboard.
If hope they have time and resources enough to get the old .csv fully operational again.
But if we have to abandon the .csv, it is not a big deal for the HWS-template type scripts.
The .csv files are only used for the graphs and we should then use the 7 day API-json history and cache the data  to obtain longer periods.
For now WU is slowly improving, we even have the decimals for our data back!
Offline wvdkuil
  • Wim van der Kuil
  • Mac OS X 10.13.6
« Reply #201 on: August 04, 2019, 08:17:56 AM »
. . . shortened . . .
Ken True (Saratoga) found a solution for the data without decimals, it seems to work and is tested for a few days at
http://wd34.weather-template.com/pwsWD/index.php?theme=user
The current data with decimals will really make a nice dashboard, I think
@ ONLY for WU - uploaders!
There were no problems during testing and WU itself is still using that "&numericPrecision=decimal" in their API-calls for the dashboard.
So I attach a folder, with  the old version (just for safe keeping) and the current version of  w34_load_files.php
« Last Edit: August 04, 2019, 08:20:03 AM by wvdkuil »
Offline bitsostring
  • Oregon Scientific WMR200
  • Edinburgh, U.K.
  • Win NT 10.0
  • Chrome 70.0.3538.102
    • Home Weather Station
« Reply #202 on: August 04, 2019, 08:40:08 PM »
I was looking at an American site today and could not help noticing that am/pm was treated differently in small temp and wind blocks?
It's meant to be fun. . .
Offline ms372591
  • Win NT 10.0
Weewx realtime.txt and Acurite 02032C Barometer Reading
« Reply #203 on: August 04, 2019, 10:15:34 PM »
Wim, does WD34 interpret the barometer setting that comes from the Weewx Cumulus realtime.txt file. It always appears high compared to the reading on WU and on my Acurite display. I realize this is probably a Weewx problem, but wanted to see if anyone has experienced the same problem.
My weewx site is https://klephtic-math.000webhostapp.com/index.php and my WU site is https://pendulous-here.000webhostapp.com/
Offline wvdkuil
  • Wim van der Kuil
  • Mac OS X 10.13.6
« Reply #204 on: August 05, 2019, 06:36:30 AM »
:D
Do you still have the url to the site?
Those times are coming from the uploaded realtime file and are processed in the same way.
I added extra code to the wind script end of July, but that has no effect for that site.
I have to check the upload file and see what the exact uploaded time strings are. And copy that file to adjust the code.
Offline wvdkuil
  • Wim van der Kuil
  • Mac OS X 10.13.6
Re: Weewx realtime.txt and Acurite 02032C Barometer Reading
« Reply #205 on: August 05, 2019, 07:04:10 AM »
The scripts just display the values received. They recalculate if another unit is requested than the one in the upload-file
WU => upload file 1010.84 hPa / 29.85 inHg  => displayed correctly on the dashboard for hPa and inHg
Weewx => upload file [10] => 29.89 inHg   => displayed correctly on the dashboard for hPa and inHg
Maybe you are uploading station-pressure to the dashboard and the correct sea-level pressure to WU?
I see there is another discussion about this at http://www.wxforum.net/index.php?topic=37576.0
Offline bitsostring
  • Edinburgh, U.K.
  • Win NT 10.0
« Reply #206 on: August 05, 2019, 09:45:46 AM »
:D
http://pokie.hopto.org/waptx/pwswd/
Owner is a regular visitor to the forum  :)
Offline wvdkuil
  • Wim van der Kuil
  • Mac OS X 10.13.6
« Reply #207 on: August 05, 2019, 10:24:43 AM »
Caused by a  leftover from the "2017" version, adapted script attached,
@all only for WD-clientraw users who use this small block.
Offline ms372591
  • Win NT 10.0
  • Chrome 76.0.3809.87
« Reply #208 on: August 05, 2019, 11:20:23 AM »
I went into the Weewx config file and had it subtract 26 from the pressure being sent via the realtime.txt. I'm not sure if that's the correct way to do it, but it's close.
Offline kentsimon
  • Win NT 10.0
  • Firefox 67.0
    • Tube & Brew
« Reply #209 on: August 05, 2019, 02:08:07 PM »
I didn't even notice the different am/pm on my template. I loaded the fixed w34_livedata and now it is perfect. Thankyou everyone!
http://pokie.hopto.org/waptx/pwswd/index.php
