Author Topic: HWS-template (WD34) July version available  (Read 3744 times)
Weather Display and 1 Guest are viewing this topic.
Offline wvdkuil
  • Wim van der Kuil
  • Leuven Belgium CET
  • Mac OS X 10.13.6
  • Chrome 75.0.3770.100
    • My PWS at Leuven Belgium Europe
Re: HWS-template (WD34) July version available
« Reply #15 on: June 28, 2019, 10:36:38 AM »
the WD clientraw label at the bottom of the pages has a strange number after it..does not seem to be the WD version and build?
As @bitsostring already explained I needed a WD34 version-number.  Did not want to much numbers and the not often used build can be easily  checked in the debug console.
Offline bitsostring
  • Oregon Scientific WMR200
  • Edinburgh, U.K.
  • Win NT 10.0
  • Chrome 64.0.3282.140
    • Home Weather Station
« Reply #16 on: June 28, 2019, 10:58:31 AM »
Could you test if it works by copying the w34_settings1.php from the April release and the starting easyweathersetup.php
That should work.
Just realised I still have the .zip you sent for the April version, so I will test that first.
UPDATE: Yes, it works fine, thanks  :)
URL as left but /pwsnew/ instead of /pws/
« Last Edit: June 28, 2019, 11:44:14 AM by bitsostring »
It's meant to be fun. . .
Offline mldenison
  • Win 7/Srvr 2008R2
    • York, Pennsylvania USA Weather
« Reply #17 on: June 28, 2019, 11:18:57 AM »
https://www.m82a1.us/pwsWD/w34_module_test.php
Click on load files
w34_load_files.php (86) METAR not loaded API=ADD YOUR API KEY
The METAR file is not loading because there is no API set for that file
Sorry, WIM.  I missed entering that API.
Offline bitsostring
  • Edinburgh, U.K.
  • Win NT 10.0
« Reply #18 on: June 28, 2019, 01:34:08 PM »
Prob a dumb question...but how do you exit the boxes that pop up when using the menu entries?  ie. the weather alerts or weatherflow map?
Click "Home" or browser left arrow (back one page).
Offline bitsostring
  • Edinburgh, U.K.
  • Win NT 10.0
« Reply #19 on: June 28, 2019, 01:37:32 PM »
Webcam pop-up not working. . . I haven't had this problem before  :?
http://swanston.maui.co.uk/pwsnew/
Offline wvdkuil
  • Wim van der Kuil
  • Mac OS X 10.13.6
« Reply #20 on: June 28, 2019, 02:27:19 PM »
Did you fill in the link in easyweathersetup?
It still seems to be the default one, including the typo
As the img is only used as a background img the whole pop-up is white, I think.
If there is a valid image I can test further.
 :oops: :oops: :oops: :oops: :oops: :oops:
Use the attached one, with testing just before the self-imposed deadline I commented both possibilities  (img or video) in the script.
« Last Edit: June 28, 2019, 02:39:06 PM by wvdkuil »
Offline NorCal Dan
  • Dan - KJ6RGX
  • Davis Vue/Win10
  • Ocean Park, WA.
  • Mac OS X 10.10.5
    • Traveling RV Weather
« Reply #21 on: June 28, 2019, 02:39:19 PM »
click anywhere outside the pop-up
On my system the only way I can find to return to the main display (without using the browser back button) is by hitting either the home button in the header or from the drop down menu.  Clicking outside the pop-up does nothing.  Why is there no "X" on the pop-up box?
Offline bitsostring
  • Edinburgh, U.K.
  • Win NT 10.0
« Reply #22 on: June 28, 2019, 02:44:22 PM »
For those items under Menu Extras that's exactly right (see reply #18 above). There is an X on all the pop-ups generated on the main page, but you only have to click outside the box for them.
Offline wvdkuil
  • Wim van der Kuil
  • Mac OS X 10.13.6
« Reply #23 on: June 28, 2019, 02:56:55 PM »
Popups are the graphs, tables a.so. They have no headers and meno of their own, they are "superimposed" on-top of the normal page with the blocks. They always have a X on the left corner as I tested  at https://www.shermanctweather.org/pwsWD/index.php
You have to click on the X (or outside the box) to get back to the normal page or to the menu.
Test it, pop-up a graph,
click on menu => pop-up disappears but no menu yet
click again on the menu => menu opens
Extra pages as the menu entries   they fill the whole browser window, can therefor have no X, have their own bar with the clock, footer and the small blocks top-row.
You can go to any other page (including the home page) by opening the menu directly.
You can see this behavior better by switching to the dark theme.
« Last Edit: June 28, 2019, 03:02:51 PM by wvdkuil »
Offline bitsostring
  • Edinburgh, U.K.
  • Win NT 10.0
« Reply #24 on: June 28, 2019, 03:03:10 PM »
:oops:
That's done it, thanks Wim  :) (I've even managed to centre my 4:3 image!)
Offline bitsostring
  • Edinburgh, U.K.
  • Win NT 10.0
« Reply #25 on: June 28, 2019, 07:08:32 PM »
I set NOT to use Twitter in contact info, but bio_popup still showed the Twitter area.
(I've deleted it altogether in my page.)
Offline wvdkuil
  • Wim van der Kuil
  • Mac OS X 10.13.6
« Reply #26 on: June 28, 2019, 08:08:05 PM »
:oops: Again left in test-code "if (1 == 1)" and that is true
updated script attached
Offline bitsostring
  • Edinburgh, U.K.
  • Win NT 10.0
« Reply #27 on: June 28, 2019, 08:26:37 PM »
Thanks, Wim  :)
Offline bitsostring
  • Edinburgh, U.K.
  • Win NT 10.0
« Reply #28 on: June 28, 2019, 09:25:47 PM »
No UVI in "This hour:" forecast in DS Current Conditions block?
No way to use extra_tmp_c_small.php?
« Last Edit: June 28, 2019, 11:14:08 PM by bitsostring »
Offline johnmac78
  • Westminster, Massachusetts USA
  • Win NT 10.0
  • Chrome 75.0.3770.90
    • Village at Old Mill - Weather
« Reply #29 on: June 29, 2019, 12:29:52 AM »
Uploaded the July Version and cannot see where to add my webcam address in "webcam_c_block.php". I see where it says it goes, but not sure where to put it. It says as set with "easywaether". There was no place in "easyweather" to set the location. Thanks for any assistance. www.scannorthcounty.net/pwsWD/
John
John
scannorthcounty.net
