Not sure what I am doing wrong as I have checked and rechecked things many times. I am able to upload clientraw.txt to my server but the api link to update Meteotemplate does not seem to be functioning as it should.
Here are my relevant entries in config.txt
update meteotemplate=Y //Y or N
meteotemplatepass=xxxxxx
meteotemplateurl=https://www.spanishhighs.co.uk/meteotemplate/api.php
meteotemplatefast= //Y for 1 minute updates
This should produce a URL such as this
https://www.spanishhighs.co.uk/meteotemplate/api.php?U=1486255070&T=25.3&H=79.9&P=1010.1&W=5.6&G=7.8&R=0&RR=0&B=272&S=788&PASS=xxxxxx
In fact if I enter that URL (with correct pw!) I receive a SUCCESS message and the system is updated accordingly.
So, the above URL string cannot be created as it should by Consolewd. Can anybody offer any solution as to what I am doing wrong or how I can fix?
Richard
the data to be sent is put in a file
meteotemplatedata.txt
and curl is used to send that
(and the output from that send is put in a file called meteotemplateout.txt)
curl needs to be available in /usr/bin/curl
Thanks Brian
See attached screenshot. I seem to have Curl enabled on usr/bin but still not working output to meteotemplateout.txt
Got to be something simple but beyond my knowledge and ability I’m afraid
what shows when you run cronmeteotemplate
Nothing. cronmeteotemplate: command not found
Yet I downloaded and unzipped the whole file from http://www.weather-display.com/downloadfiles/consolewd64desktop.tar.gz
but you need to run it like
./cronmeteotemplate
Response is : bash: ./cronmeteotemplate: No such file or directory
Hi Brian.
Screen extract from sudo ./consolewd
** closed custom tag out file
Doing CWOP
updating wunderground
Sending WU data now
updating meteotemplate
Updating meteotemplate UTC ->1561215901
Error ./cronmeteotemplate File not Found
updating PWS
Error ./cronpws File not Found
Sending pws data now
updating records to ini file
Update:
The version I downloaded from http://www.weather-display.com/fileslinux.php was
Weather Display for Linux console 64 bit Linux desktop Version on 21 June 2019 - 22:40:04
That zip archive doesnt contain cronmeteotemplate nor cronpws
I then copied over those 2 cron files from
Weather Display for Linux console 64 bit Raspberry pi3 Version on 7 June 2019 - 22:23:44
Only problem remaining seems like getting the cronmeteotemplate permissions file working. When run it I get
bash: ./cronmeteotemplate: Permission denied even though I have changed permissions to 777
you cant run a raspberry pi version
I did not realise those files were missing
I will update and let you know
try a new download update
Works perfectly now!
Thanks for your efforts Brian.
Regards from Spain
