Need Help please
Need help please…
I got the VP2 Pro Plus and Weatherlink Live
Trying to connect it to WD…but cant get the data to start to come over.
Not sure where I went wrong. I did input the IP address…
Is anyone available for a call? I am on the West Coast of the US.
Paolo
UPDATE
So I started to receive data…BUT it is not the same data as I am seeing on my console.
Wonder if I am receiving someone else’s data…
P
Is it very different, or just a bit off?
what you need is to know the IP address of the WLL device
and then set that in the weather station type setup
then the separate crondaviswll.exe program should be running and getting the raw data…yes?
I think I have the IP address…so all good there.
didnt install crondaviswll.exe where do I get that?
Just a bit different. They match what is on WLL but different from console…which is strange
crondaviswll.exe is included with the latest version of weather display
you should see it running in the windows system tray as an icon there…
click on that icon
so the values in WD do match what shows on the davis WLL app ?
I will be 100% honest… I am a mac guy…and have this windows computer for my WX stuff…so no idea where the windows tray is
the system tray is down in the right hand corner, by the clock
windows might be set to hide icons too
Are you talking about task manager?
If so…I dont see it there. Just see the Weather display
Found it…its running
The issue is the Temp inside number is the one that is off. Console number is different than WLL and WD!
the WLL device has its own indoor temperature I think you will find (and barometer too I think)
Temp, hum, and baro.
Thanks Guys!
Learned a lot today!
Thanks for your patience with me!
Paolo
