I seem to have lost all the historical data in my testtags.php file, only the data for June 2019 is showing. There is no record data for this year or previous years other than for June 2019. I use this info for compiling the wxrecords.php files and generation of yearly records and alltime records. I am using the updated testtags.txt file that incorporates the necessary data. Weather Display version 10.37s95. It was working fine until sometime in June.
Any thoughts on getting this data back?
John
the data in testtags comes from WD itself
so what shows in WD under view, all time records?
All Time Records/Year to Date and This Month are all the same. No records show before June 2019. All three screens are identical. Records should go back to 2013. It appears this issue started sometime in June (This month)
you can get WD to rescan for all time records from your logfiles
i.e action, convert WD logfiles to data files…tick convert all…click on convert
Followed up on these instructions and all seems to be back to normal.
Thanks for the help.
John
