Based on earlier conversations about custom files, I have created a text file to use with my webcam. I have two questions -
How do I make the wind speed show as mph? I tried using %uomwind%, but must be missing something, as that does not work. It just duplicates the knots reading rather than mph. 2nd, I do not need this file to upload to my website as I believe iptimelapse will use the local file? But, I may be wrong.
My iptl.htx file is attached for review.
John
iptl.htx.txt (101 Bytes)
it will be mph if that is the unit of wind setting in WD
otherwise use
%windinmph%…Average wind in mph always
%gustinmph%…Gust wind in mph always
It turns out that my settings for wind speed were set to knts, not mph. Once I corrected that, the original custom file I created worked just fine. Not sure how that got changed, as the universal setup page was correct. I just clicked OK and it reverted to the correct settings. I never changed anything prior to that, but had numerous recent power failures that may have scrambled things. I think I am back to normal now.
