Davis WLL and crondaviswll?
Does crondaviswll need to be run with weather display to get WLL data? Also does it pass a long the extra senors that i have? Temp/Hum sensor.
Thanks!
HI
yes, it needs to be running
and yes the extra sensor data should work
but if you could email me the daviswlldata.txt file that is created, where WD installed
then I test/check on that
Brian, i have 3 files Daviswlludpdata , Daviswlludp , Daviswll…but no daviswlldata.txt
I sent all 3 to you.
OK, it looks like your extra temp data is sent as
“txid”:2,
“temp”:83.0,
“hum”:45.1,
and not as
temp_1
I will add support for that now and update
try a new .zip update
that extra temp/hum data should show under view, davis vp extra temp/hum
Thank you. :smiley:
