Bohler download bug fixed
Thanks to everybody who alerted me to the GFS download problem. I got hold of Sam, and he fixed it within minutes. It was a bug resulting from preparing for the June 12 GFS changes. It’s working now, so WXSIMATE and WXSIM-Lite should both be fine now.
Tom
Hi Tom,
thanks, yes it does… :smiley:
http://gfs.wxsim.com/lite/50.44/12.71
Stefan
Hi Tom,
Great to hear that! Thanks!
Brgds,
Oebel
Assen, the Netherlands
Still not working i Denmark - both Henrik https://www.silkeborg-vejret.dk and I https://www.cpvejr.dk had to change to McMahon…
Best regards
Christian
Yes, same for me on 7 pm run.
Still no GFS data.
Brgds,
Oebel
Tried McMahon and Bohler. Both same problem.
No GFS data.
Brgds,
Oebel
Still a problem for me. I’m still seeing “bad data” for Download and “old data” for Forecast each time I run WxSim-Lite.
Steve
OK, I’m seeing “bad data”, too. Checking to see what’s bad about it.
Same here in Italy
The 18Z GFS has just tried to come in and is bad as well.
OK, working with Sam. I found that the barometric pressure is not being read correctly after the initial hour. We’re going to revert back to the current, official data. We’d switched to the parallel data, which is going to become the official data on June 12. Hopefully it will be OK shortly (maybe give this half an hour or so). Then we will experiment in the background to see what was happening with the parallel data.
Thanks!
Tom
I think we’ve got good data again, now! 18Z should be ready and good.
Tom
Working over here, thanks Tom!!
Looks like it is resolved.
Thanks!
Brgds,
Oebel
Confirmed! Thanks for the quick solution.
This morning I am seeing yesterdays 18 hrs as the last good download with a bad data error presumably on trying to get todays 0 hrs file.
Same here, Stuart. However the Bohler 06 has just come in okay.
