Author Topic: WH3081 Weather Station  (Read 458 times)
Offline Oz Pom
  • Chrome 64.0.3282.140
« on: June 06, 2019, 06:39:28 AM »
I have had a WH3081 weather station working fine for a number of years after a La Crosse gave up. I recent weeks I have had problems with data from Base Station via USB to Weather Display Software. I am running Win 10 on an oldish dedicated PC. As anomalies started happening I noticed glitch data, the maximum Temperature reading window goes to say 19.5c, while actual temperature is say 8.6c, (yep it is a decent cold snap here in Victoria). Now data to WD stops. The WH3081 base station is still receiving data correctly from the instruments in the garden. I have read the recommended power options for Win 10 and done all including the USB setup option to disabled. I then decided to do a new install on a laptop and connect under evaluation mode, still the same problems
 I pull all power from the inside base station and disconnect USB cable. I then power up and wait untill all outside data is received. I then connect USB and execute Weather Display Software. All comes up with correct detail on WD from base station. Then I received a glitch data,  then after that the readings freeze.
I then decided to go back to first PC with registered software, made sure the the USB thing was disabled. All seemed oK for a while then again the max temp jumped to high reading. All other readings were correct on WD screen from WH3081 display. Then a regular send of data stops. I have even set WH3081 to factory defaults. I know the WH3081 is a cheap Weather Station but as a pensioner budget is tight, any resolves or am I correct in my thinking my hardware is at fault. Do you have any suggestions for a decent Weather Station that can be bought in Australia, say, around $300.
Offline Matrix
  • Czech Republic
  • Win 7/Srvr 2008R2
  • Chrome 74.0.3729.169
    • Meteocentrum Olomouc
Re: WH3081 Weather Station
« Reply #1 on: June 06, 2019, 09:08:02 AM »
All WH stations are s**t.
I wonder manufacturers are not ashamed to sell such scrap.
If you want a good station at least Davis Vue or Pro-2.
« Last Edit: June 06, 2019, 09:10:57 AM by Matrix »
  • Davis VP2
    • Weather Display
« Reply #2 on: June 06, 2019, 09:50:34 AM »
which version/build of WD?
and do you have ticked that its a WH3081 type station in WD?
also you could try a complete power down/reset of the console
Offline Oz Pom
« Reply #3 on: June 07, 2019, 12:50:03 AM »
Hi Thanks for the replies so far. Yes I would get a Davis if I could afford one. I have the latest version of WD installed that Brian has posted. I have ticked the right box in Weather Station configuration. The WH3081 may be sh*t but it has worked perfectly for the past five years and with WD I have been uploading data to Wunderground and UK Met Office WOW with no problems. Cheers.
  • Davis VP2
  • Android 7.1.1
  • Chrome 74.0.3729.157
    • Weather Display
« Reply #4 on: June 07, 2019, 03:27:51 AM »
Have you tried a complete power down/ reset?
Offline Oz Pom
« Reply #5 on: June 10, 2019, 07:00:22 AM »
Hi, yes I have tried a complete power down and factory reset. I have been away for a few days and the WH3081 has not been connected to computer. It appears the Base Station is receiving data from external devices but it is not recoding any history.  I am looking at a new weather station. I'm a retired pensioner and budget is tight and found this one. WS1081 Ver2 TESA Solar Powered Touch Panel Weather Center with PC interface. My budget is up to AU$300.00, this one is AU$251.80. I cannot afford $1000+ or should I say "She Who Must Be Obeyed" has made this ruling. Any advice will be appreciated as I want to continue weather monitoring. Cheers
  • Davis VP2
    • Weather Display
« Reply #6 on: June 10, 2019, 08:40:11 AM »
there are a lot of re branded weather stations
do you have a link to that station?
you could look at getting a weather flow station?
Offline Oz Pom
  • Davis VP2
    • Weather Display
« Reply #8 on: June 11, 2019, 06:55:01 PM »
that is the WH1080/1081 type station
i,e the same as the WH3081 but no solar
Offline Oz Pom
« Reply #9 on: June 14, 2019, 07:09:28 AM »
Thanks for your continued support over the years. I had a look at Weather Flow but for our region it is not available at this time.  I have found this Weather Station within my budget is this compatible with WD?
https://www.instrumentchoice.com.au/instrument-choice/weather-stations/home-weather-stations/100-300-weather-stations/wireless-pro-weather-station-with-usb-upload-ic-wmr89
  • Davis VP2
    • Weather Display
« Reply #10 on: June 14, 2019, 10:13:17 AM »
that looks like the OS WMR89
and yes that is supported
