I was able to find the source to lihid.so and tried to build a 32 bit version. Unfortunately all I have is a 64 bit machine and when you do a ‘configure’ to build the makefiles, it assumes the architecture of the machine you’re running on. I’ve tried to force it to compile and load 32 bit, but I’ve had no luck.
If you have a x86_64 architecture available and can recompile your code so that consolewd64desktop.tar.gz has 64 bit rather than 32 bit binaries, that would be the far easier route.
