I think that will be related to “$filemtime == == Wed, 31 Dec 1969 16:00:00 -0800”, in other words it isn’t correctly reading the timestamp of the file.
“Niko hit the nail on the top”
If you run http://24.108.124.18/weather34WDbeta/w34_module_test.php
And select middle top-row => forecastWXSIMblock.php => click “Test-it” the message reads:
Warning: filemtime() [function.filemtime.html: stat failed for ../plaintext.txt in E:\htdocs\weather34WDbeta\w34_util_wxsim.php on line 41
The script can not get the filemtime = last-modified-time of the file.
This filemtime check is there so that we do not run the plaintext-parser.php multiple times when there is no new file during its 6 hour life.
The first thought, maybe windows using "" and the file starts with “…/” ??.
Second thought: running Kens script directly http://24.108.124.18/weather34WDbeta/wxsimPP/plaintext-parser.php the correct date time is found.
That date time is coming from the plaintext.txt file
But I can not access that file to check, all links do not work
http://tzwd34beta.ddns.net/../plaintext.txt
http://24.108.124.18/weather34WDbeta/../plaintext.txt
Have to study this. Problem is I do not have a windows website-server available. Will take some time.
Adapted script to test with in next post!
OK, can you test this version?
It will use the date-time from the plaintext-file as parsed by Ken’s script, only if the stat fails.
I also found the culprit, your plaintext.txt is on a other location then expected
$plaintextFile = '../../wxsim/plaintext.txt'; // location of the WXSIM plaintext.txt
Normally the file is in the webservers root.
That is why the file-name-location in the parser is “…/…/plaintext.txt”
And in the other scripts “…/plaintext.txt”
Change line 22 in w34_util_wxsim.php from
$plaintextFile = '../plaintext.txt';
to
$plaintextFile = '../wxsim/plaintext.txt';
Will add it to the documentation
w34_util_wxsim.php.zip (3.42 KB)
The author just released an update where sites could be blacklisted - so I now don’t have it display on my m82a1.us sites.
It’s strange that April and July menus are different…
Not strange at all, the original release contained hundreds of html “notices” / problems.
I removed them all, but had to rewrite 90% of the code.
I can probably change the code in such a way that you do not have to blacklist the template. I already changed the code, but need the extension to test with.
But that is for ‘one fo these days’ later next week.
Tomorrow it is “conformation” day for the grand children, to important for them and for me to miss that large family gathering.
Hi Wim,
I see a problem with weather alerts.
It shows the distance of a discharge (Nexstorm).
Instead of 1509 km he gives an alarm because of a thunderstorm at 1,509 km.
See red blocks.
https://www.weerstation-assen.nl/actueel-weer2.php
Edit: After refresh alarm message is gone. See picture how it looked.
Furthermore, it looks great. Many thanks!
Brgds,
Oebel
Can you please PM me the link to the NSRealtime.txt file you are using? Then I can test / check.
The comma in the distance is a number_format error, I will check that.
The alert is always given if the “lightningtimeago” is less then 500 seconds.
Both the WeatherFlow or Boltek are used for that. Boltek has priority if both devices are available.
Hi Wim,
You have PM.
Brgds,
Oebel
Wim, when is the WXSIM parser ‘plaintext-parser.php’ run, meaning at which stage during the loading of all the other templates? Is the WXSIM parser ‘plaintext-parser.php’ run before the ‘w34_util_wxsim.php’? If yes, then the value of the path to the ‘plaintext.txt’ data file set in ‘plaintext-parser.php’ template should be passed on to the ‘w34_util_wxsim.php’ template and not be fixed in the ‘w34_util_wxsim.php’ template, thus preventing the current situation, that is ‘assuming’ that a file/template is in the root directory when that file/template can/could be in a totally different directory.
The WXSIM parser ‘plaintext-parser.php’ needs to be edited in order to provide the required information for its proper operation - the ‘w34_util_wxsim.php’ template should not have be edited.
Note: On all the systems I have operating on my home/office server as well as my online server, no template, no data file is place in the root directory - for me, the root directory is ‘sacred’ and not to be used for any purposes except for an .htaccess routing file.
One thing I noticed with this beta on 12 hr. clock it doesn’t change from am to pm till a screen refresh is done.
https://www.shermanctweather.org/pwsTEST/index.php
Tom
Attached correct formatted distance number.
There is only an alert when the age is less then 600 seconds
advisory_c_small.php.zip (3.37 KB)
w34_util_wxsim.php serrvices all wxsim blocks/popups,
it is loaded by all wxsim scripts as the first include
and it then
=> compares the age of plaintext.txt versus the age of the cache arrays
==> if a new file arrived
===> it loads the parser
===> and saves Ken True’s arrays to the cache
==> if no new file arrived it loads the arrays from the cache
=> and returns the arrays to the calling script
Then the normal scripts can print what they need.
The WXSIM parser 'plaintext-parser.php' needs to be edited in order to provide the required information for its proper operation -Yes it should be edited as it is the exact copy of Ken True's script. I stopped making small changes in someone else scripts as it always resulted in large problems
the 'w34_util_wxsim.php' template should not have be edited.As w34_util_wxsim.php starts before the parser they both should now the exact location to check the filetime and to read the file
Note: On all the systems I have operating on my home/office server as well as my online server, no template, no data file is place in the root directory - for me, the root directory is 'sacred' and not to be used for any purposes except for an .htaccess routing file.I agree with that 100%. That is why I have all my template/scripts in separate folders.
So I will make clear in the documentation that there are 2 locations to check.
As most wxsim users upload to the root, I leave the current relative addressing as is.
Thanks for finding that, it has been the same script form months.
The 24 hour clock can not have that problem. I will test tomorrow around noon.
If possible can you test this “enhanced” version.
clock_c_small.php.zip (2.32 KB)
Hi Wim,
The problem is not solved.
A storm warning is displayed when the distance is hundreds of kilometers.
Brgds,
Oebel
I checked the scripts.
advisory box displays a message when
1.1 the age of last-strike = less then 500 seconds
1.2 and there are no other more important messages -
A notification is always shown when the age of last-strike = less then 700 seconds
On both cases the distance is shown but it is not used to filter the messages.
I only have a Weatherflow device and IMHO that device only signals strikes when they are close by
I received the scripts as is, no explanation.
I would be happy to alter the scripts if there is a description of the algorithm to use.
New beta version 2019_06_10 available at http://wd34.weather-template.com/beta.php
Includes all discussed changes.
Wim, rather than asking the user to check that the two locations be edited to point to the same location, could you not ask for the location of the ‘plaintext.txt’ data file in the main configuration template (as you ask for the path to the realtime data file) once the user has selected to use WXSIM when that product has been installed?
Wim,
I tried the new clock_c_small.php but now it stays am even after a screen refresh.
Seen at https://www.shermanctweather.org/pwsTEST/
Tom
This one should do.
I tested for midnight last night, not yet for noon.
Wim,
That one works with a screen refresh. I’ll let you know tomorrow if it changes automatically.
Tom
