I just installed this.
I am wanting to get UV data from darksky, but UV/Solar block is not showing that data.
On a few blocks I am seeing the time/date displayed incorrectly.
Time is wrong and date is included.
After 3 refreshes the time displays correctly
It seems that the setting is incorrect.
Did you copy the settings from another version?
Or did you set them from scratch?
Thank you!
That is an error caused by wxsim script.
Will look into that tomorrow.
=== :oops:
In the moon-block an old error returned. Attached a better version for the west of greenwich countries.
moon_c_block.php.zip (4.39 KB)
I think the date/time issue is related to firefox. I tested with chrome, it it works fine
Ooops. sorry, I missed that one :oops:
It appears to have fixed the problem.
Thank you
It appears that my max/min wind gust is not working in the small display on top. 12:58 has not come yet today
http://southernctwx.com/WX/index.php
Just started working…disregard!
The current conditions block has a line of untranslated text - to English:
Is this your HWS site: http://www.m82a1.us/pwsWD/ ?
Check the setting for the language of the DarkSky forecast. You can have that set to a different, often more local, language.
It is set to Dutch (Netherlands), should be your English.
http://www.m82a1.us/pwsWD/_test.php?test=forecastDSdaily_popup.php
If the language is set correctly the cached file is still valid for about an hour.
Then the next load of the Darksky forecast will remove the dutch file.
@ALL Please always post the URL to the site. Especially if you have multiple versions
Sorry, Wim. That’s the April version.
Here’s the July version: https://www.m82a1.us/pwstestWD/index.php
Even though I didn’t think I was using DarkSky, after I entered the API, the language translation worked.
Also, when using the Google Chrome browser, the menu link in the header doesn’t show. It’s fine on the April version. And it works fine in my Pale Moon browser.
The current conditions block displays also a one-hour “forecast”. And WD does not supply that info.
Also, when using the Google Chrome browser, the menu link in the header doesn't show. It's fine on the April version. And it works fine in my Pale Moon browser. ThanksI could not replicate that problem with my Chrome browser. See attached screenshot === In some browsers your webcam image is not shown as the link http://182.168.1.65:82/?_1559896445 should be https also.
Mixed Content: The page at 'https://www.m82a1.us/pwstestWD/index.php' was loaded over HTTPS,
but requested an insecure image 'http://182.168.1.65:82/?_1559896445'.
This content should also be served over HTTPS.
Also did the upgrade to the beta version.
I do not see the option to refresh the data every xx seconds. (Nice for wind,uv,solar)
Also the metarbox is setup good, but on click nearby it gives “EBBR Brussels” and in the same windowbox earthquacke.
Without the URL to your website there is not much I can do to inspect those things.
Be aware that you use a beta version. The whole purpose of a beta program is to find remaining errors.
Do not use this version for production as in a few weeks the official release version will be available.
All blocks have different refresh-times. Those times are set in w34_blocks.php. Example
$script = 'temp_c_block.php';
$blck_ttls[$script] = lang('Temperature').' °'.$weather['temp_units'];
$blck_rfrs[$script] = 110;
The temperature block is refreshed every 110 seconds.
The nearby metar airport code is set in easyweather-setup. You need also to set the API key for that nearly at the bottom.
I figured out the missing ‘Menu - Settings’ in the header.
I have an add-on that displays current selected stocks at the top of Chrome pages. It pushes down the page. In the April version, the pwsWD header is below the ticker bar. In the July release, while the page is pushed below the ticker bar, the ‘Menu - Settings’ links remain under the ticker bar. Here’s with/without the ticker bar.
pwsWD: https://www.m82a1.us/pwstestWD/index.php
I have no fast solution for that.
All 1276 lines of the page are correctly contained in the < body > tags
No html errors: https://validator.w3.org/nu/?doc=https%3A%2F%2Fwww.m82a1.us%2FpwstestWD%2Findex.php
To test and see what is happening, I need to know what add-on you are using.
Wim, just curious…
Why would my WXSIM forecast indicates that it is ‘Offline’ - the WXSIM forecasts are automatically produced every six (6) hours, thus, there is no reason for showing the WXSIM forecast as being offline.
Temporary web link: Tzouhalem-Maple Bay Weather
