MQTT mosquitto
I’m trying to get WD to write information to my mqtt broker mosquitto.
But I recieve error and disconnect
1558386620: New connection from 172.16.7.28 on port 1883.
1558386621: New client connected from 172.16.7.28 as wd (c1, k120).
1558386630: Socket error on client wd, disconnecting.
It’s a clean setup of mosquitto without authentication or ant security at all. I thought it was best to try that it works first.
its not very clear where you are seeing those error messages exactly
I recommend you to wait a couple of days. Brian is woking on sending each value as its own tag. Right now WD sends all sensors as one tag I you need to “parse” it to use it.
but that is not going to help with this error
Did you ever solve this issue? I keep disconnecting message too.
its not all that clear to me what the issue is
is that the MQTT connection by WD is being lost?
it is set to auto reconnect…
